Old 03-05-2017, 10:44 AM   #1
edhd58
edhd58's Avatar
Default 42 Ford G 6 cylinder generator
What am I missing or overthinking here.
This is off my 42 G six cylinder.
I have had several instances where either the generator is moving or the belts loosen greatly, and I am betting on the generator moving after I've tightened it down good. Once this caused overheating to the point of boil over.
When I pulled it off the car the first time it had two same size bolts with a pile of washers over that weird shaped hole. This is also as real pain in the *&^ to get both belts tight and hold everything in place as you're tightening the bolts.
Is there something I am missing, overlooking or is this just a bad design.
Next question is what can I do about the odd shaped hole? I am considering a piece of flat 1/4" thick steel made to cover that odd hole instead of washers.
edhd58 is offline   Reply With Quote
Old 03-27-2017, 01:12 AM   #2
Vintage Copper 47
Vintage Copper 47's Avatar
Default Re: 42 Ford G 6 cylinder generator
My generator has a washer with two holes.. basically to match/fit the pivot hole/slot & adjustment slot...
That keeps equal pressure on both parts of the bracket from moving.. It will be hard for me to take a photo as you know, I am still using the bracket to support my alternator bracket..
Try making a long oval washer out of 1/8 flat bar stock with the holes just large enough to fit the bolts and aligned to fit both slots.. that should do it.
WALT
Vintage Copper 47 is offline   Reply With Quote
Old 03-27-2017, 01:00 PM   #3
49fordv8f4
49fordv8f4's Avatar
Here is a photo of the generator mount. You can see the washer with two holes as VG47 mentioned.
Mark
49fordv8f4 is offline   Reply With Quote
Old 03-27-2017, 10:38 PM   #4
Vintage Copper 47
Good photo Mark... mine was greasy but not rusty... LOL
Old 03-27-2017, 11:22 PM   #5
edhd58
edhd58's Avatar
excellent, thanks guys thats exactly what i was needing.
