Old 02-24-2017, 04:34 PM   #1
wrndln
Default Broken Zenith 2 carb
I bought a broken Zenith 2 carburetor at a swap meet a year ago. I paid about $12 for it thinking at least the bottom section was probably usable. It has a broken flange where it bolts to the intake manifold as you can see in the pictures. It had crud all over it, so I couldn't tell its condition, even what version of Zenith it was. I beadblasted it a few days ago and it looks pretty good. I am wondering if the broken off flange can be reattached in some manner or the top section is hopeless and is scrap. If anyone has any constructive comments as far as whether the top can be save, I would appreciate it.
Rusty Nelson
Old 02-24-2017, 04:36 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Broken Zenith 2 carb
Ive seen em welded/brazed before - its fixable. Wont be easy as its broken into the actual intake not just the ear broken off...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-24-2017, 04:45 PM   #3
Gunmetal blue2
Gunmetal blue2's Avatar
Fine a good welding shop and it can be welded back to gether. We weld high performance engines that are cracked and they hold together.
Gunmetal blue2 is offline   Reply With Quote
Old 02-24-2017, 04:46 PM   #4
Bulligen
Bulligen's Avatar
It will work just like new if you braze it! I love fixing broken things other people write off!
Bulligen is offline   Reply With Quote
Old 02-24-2017, 05:41 PM   #5
wrndln
Thanks to all that posted responses. One addition to the original post. It is apparent that several of you believe the broken off flange can be reattached. Question: Can the repairs be made to look transparent, like brazing, after painting the carburetor and installing it on the intake manifold? It would be nice for the carb to look like it was never repaired once installed.
Rusty Nelson
Old 02-24-2017, 05:47 PM   #6
old31
Would JB weld work?
Old 02-24-2017, 05:48 PM   #7
1931 flamingo
1931 flamingo's Avatar
Probably depend on your "skills" at filing, painting, etc.
Paul in CT
Old 02-24-2017, 06:00 PM   #8
Dave in MD
Rusty,
Generally it is the other ear that breaks off form someone using to long of a bolt.
A friend has a Zenith side bowl that has been brazed on his Fordor that has held up very well. We even put a Heli Coil in it as the threads were bad. Find a good welder or some who knows brazing and then make sure the top flange is flat.
Dave
Dave in MD is offline   Reply With Quote
Old 02-24-2017, 07:52 PM   #9
fastroadster
They have that aluminum "Solder" you use a torch to solder it. Works real good.
fastroadster is offline   Reply With Quote
Old 02-24-2017, 08:30 PM   #10
Mitch//pa
Toss the top half and get another. They are plentiful
Thats my opinion
Old 02-24-2017, 08:36 PM   #11
Russ/40
Russ/40's Avatar
Braze it. Or, my preference is silver solder with a good flux. It flows real well, and you wont have to bevel grind the edges. Use a hefty plate with the two bolt holes drilled and bolt it all together for holding the proper position. With paint, no one will ever know.
Russ/40 is offline   Reply With Quote
Old 02-24-2017, 09:34 PM   #12
wrndln
I hate to toss a repairable part, so I would rather fix it is reasonably possible.
Rusty Nelson
Old 02-24-2017, 10:37 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
Clean all the oil off and braze it as Russ said by using a heavy plate to hold the parts. Use a Demel and file to clean any excess off the crack, then paint it, and no one will know.
If it was mine, I'd buy another top, but if you want to repair it, I'd do as Russ said. I haven't tried silver solder on cast iron breaks, but I have done several braze repairs.
Old 02-24-2017, 10:42 PM   #14
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
The good thing is it broke on the opposite side as the idle jet. I have a late side owl that broke on the jet side and doesn't idle right.
Old 02-24-2017, 11:49 PM   #15
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
" If anyone has any constructive comments as far as whether the top can be save, I would appreciate it.
It can be saved and would be an interesting project since you don't need it for your car and if you care to try. The money is little and the time is yours. But if you are planning to send it out somewhere to be done then take Mitch's advice.
Old 02-25-2017, 12:41 AM   #16
Mitch//pa
I understand what your saying, but if it breaks while your driving kaboom your rear ended or maybe a poss fuel fire over a 5.00 part that was farmer fixed.
The way the A carb is mounted hanging down off the manifold they are subject to vibration. Thats why many times i find the bolts loose when working on them .
Old 02-25-2017, 01:16 AM   #17
Terry, NJ
Terry, NJ's Avatar
Yeah you can fix it, BUT.....many hours! What's your time worth? Do you have a Bridgeport? I have a couple of B carbs with a broken ear (They break easy) I made up a 1/4" steel plate with the bore and threads and brazed it onto the old surface. The difference is that it's just the ear. It didn't break into the bore. If it was a B carb, it might be worth saving, but it's only an A carb. I'd strip it for anything good and toss the garbage into the scrap bin.
Terry
Terry, NJ is offline   Reply With Quote
Old 02-25-2017, 06:39 AM   #18
George Miller
George Miller's Avatar
Thats my opinion
plus 1
George Miller is offline   Reply With Quote
Old 02-25-2017, 10:58 AM   #19
Rancho Deluxe
Rancho Deluxe's Avatar
Originally Posted by George Miller View Post
plus 1
And if it was a Zenith 3 ??
Rancho Deluxe is offline   Reply With Quote
Old 02-25-2017, 11:00 AM   #20
Benson
ddd
Benson is offline   Reply With Quote
