Old 02-20-2017, 11:53 AM   #1
Bill Lee/Virginia
Default Inverted Coil Performance?
I recently converted my Cabriolet to 12 volt negative ground. I want to install a 12 volt epoxy filled coil (with internal resistor) in the upside position.
Question: Will the upside position of the coil degrade its performance?
Bill Lee/Virginia Peninsula
Bill Lee/Virginia is offline   Reply With Quote
Old 02-20-2017, 12:21 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Inverted Coil Performance?
No problem. Did you mean with the tower UP, when you say upside?
Anyway, with an epoxy filled coil, I don't see a problem in any position.
Old 02-20-2017, 01:35 PM   #3
hardtimes
hardtimes's Avatar
Hey Bill,
'upside' is open to Q ? Upside down or tower up, you will be ok with this coil. I use same coil for years with tower DOWN and have had excellent coil performance.
hardtimes is offline   Reply With Quote
Old 02-20-2017, 02:48 PM   #4
Bill Lee/Virginia
I want to install the coil with the tower down, the same as original Model A coil.
Many thanks for the info and advice.
Old 02-20-2017, 05:31 PM   #5
Synchro909
Synchro909's Avatar
With an epoxy filled coil, you'll be fine mounting it with the terminals down. Not so with an oil filled one.
Don't ask how I know.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 02-20-2017, 05:47 PM   #6
noboD
Look at every air cooled VW ever made. They never had a problem with the tower down.
noboD is offline   Reply With Quote
Old 02-20-2017, 08:10 PM   #7
Dick Steinkamp
Dick Steinkamp's Avatar
Isn't a stock Model A coil oil filled?
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 02-20-2017, 08:40 PM   #8
Fullraceflathead
Fullraceflathead's Avatar
Original coils were Tar filled.
Inverting a oil filled coil may overheat as their is an air pocket inside to allow for expansion.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-20-2017, 08:42 PM   #9
blgitn
blgitn's Avatar
I thought so too.
blgitn is offline   Reply With Quote
Old 02-20-2017, 08:49 PM   #10
Kurt in NJ
Kurt in NJ's Avatar
The original A coils I have taken apart were tar filled
The VW upside down coils were oil filled, rarely leaked ---modern production Bosch made in other than Germany I have had leak, the original Lucas coil in my MG is mounted tower down, oil filled and rarely leaked, modern production leaked in a week
My A has a 70s Ricks "show script" coil, it is oil filled and hasn't leaked, it's a regular coil with a cover, has very strong spark----offshore made in the pre china era
I had an epoxy coil X rayed, it looka like there is enough to turn it down to fit inside original coil case
Old 02-20-2017, 10:39 PM   #11
Dodge
I was told by a coil manufacturer that the oil filled can go straight up or straight down
but don't like to go on their sides because the air pocket doesn't cover the coils when
on the side causing the coil to overheat.
Dodge is offline   Reply With Quote
Old 02-20-2017, 10:40 PM   #12
Tom Wesenberg
Studebaker mounted the oil filled coil with the tower down, and the only one I saw leak was from a junk yard, and leaked through a rust pit. BTW this is also a 6 volt positive ground car.
