02-17-2017, 08:57 AM | #1 |
1940 Ford noisey trunk springs fix??
Has anybody experienced really noisey trunk springs on there Ford coupes?
These are new Bob Drake springs , they work fine and stay up as they should , but wow do they sound creaky! Has anybody come up with a cure for this? Thanks for any ideas. Steve |
02-17-2017, 09:03 AM | #2 |
Re: 1940 Ford noisey trunk springs fix??
Actually my originals sound as you describe as well - I just thought it as normal...
02-17-2017, 09:12 AM | #3 |
Yes those springs were designed by Ford to squeak loudly as a theft deterrent.
02-17-2017, 09:45 AM | #4 |
I've had '40s with original springs and they sounded no different than the repos.
02-17-2017, 10:15 AM | #5 |
The probably squeak because they are new.
Will settle in with use and a drop or two of oil on the big hinge rivet and where spring rests. Neither my originals nor DRAKE's repros squeaked. Maybe you have a "mouse in the house". Last edited by 19Fordy; 02-17-2017 at 11:32 AM. |
02-17-2017, 11:53 AM | #6 | |
Did you place a piece of anti-squeak material between the lid and upper mount? It was there originally. The authentic material was similar to a heavy gasket (paper) material.
02-17-2017, 12:02 PM | #7 |
Thanks KUBE I will try that. Really appreciate your help, you are a great asset to the Ford Barn.
Steve |
02-17-2017, 02:16 PM | #8 |
I bet "Kube" is onto something. Maybe the squeak is coming from the trunk lid hinges that attach the trunk lid to the car body - not the trunk lid hinges that hold the trunk lid "UP".
02-17-2017, 02:51 PM | #9 |
I sprayed mine with WD40 - all noise gone!
02-21-2017, 08:13 PM | #10 |
I ended up installing some gasket material between spring brackets and the trunk lid , then used some 3 in 1 oil on the two contact points on the coil spring. One in the middle of the coil and one on the very end stop of the spring. I would say the springs are now much quieter and not as noticeable when I open and close the trunk lid.
Thanks to all, Steve |
02-22-2017, 01:52 PM | #11 |
Good to know, I installed new trunk supports on my 46 coupe and they squeak as well
Thee Inland Emperors |
