Old 02-13-2017, 10:25 PM   #1
Chris_AAFord
Default Spring Shackle too big?
I'm rebuilding the front end of a 31 AA and this spring shackle looks too big to me but I would like to see what others think.
The front Spring and perch measure closer to 2 3/16, the shackle measures closer to 2 5/16 leaving an extra 1/8th.
Chris_AAFord is offline   Reply With Quote
Old 02-13-2017, 10:30 PM   #2
DJ S
DJ S's Avatar
Default Re: Spring Shackle too big?
Yeah, that's no good. I'll take some measurements for you in the morning to see if your perch and spring are the correct length. It also appears that you have a repro shackle, I have no experience with those but I would seek NOS shackles as I've heard the repros are no good.
DJ S is offline   Reply With Quote
Old 02-13-2017, 10:35 PM   #3
Bob C
I measured a few AA spring perches and I came up with 2 3/16" also.
Bob
Old 02-13-2017, 10:39 PM   #4
Tom Endy
Tom Endy's Avatar
Front shackle perches evidently were made in two different sizes. In the past I have bought front shackle sets that came with bushings that did not fit the perch. I have also run into this problem several times when replacing front shackle bushings, so what I did was purchase a quantity of rear shackle bushing from Bratton's and had a friend with a lathe cut the length down. The modified rear shackles bushings fit the front shackle perches that are shorter than the rears.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 02-13-2017, 10:40 PM   #5
Chris_AAFord
Bob
Thank you, I have two sets of perches and two front springs, they're all 2 3/16. Maybe i need to find NOS shackles that measure the appropriate 2 1/4.
Old 02-14-2017, 01:34 AM   #6
Synchro909
Synchro909's Avatar
I know it's not according to Hoyle, but why not just put a spacer (maybe a washer or two) in there to take up the extra. Anyone who sees it has just been run over and has other problems!
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 02-14-2017, 04:52 AM   #7
jw hash
jw hash's Avatar
AA front shackles are the same as A cars and pick ups rears. NOS ones are pretty hard to come. the shackles are not supposed to tight against the spring perches. 1/8" is no big deal. I would run them.
jw hash is offline   Reply With Quote
Old 02-14-2017, 10:26 AM   #8
Big hammer
Maybe o-rings on each side? would help to keep crap out and grease in!
Old 02-14-2017, 06:47 PM   #9
Chris_AAFord
Thanks for everyone's help I might have this issue solved.
I called berts hoping to find a NOS shackle, they didn't have any. He did go through his stock of new parts and he found that some of the shackles were just over 2.25 some were just under 2.25. He's going to send me a set that's just under 2.25 which should do the trick.
Seems like the quality control on this part might not be that good.
