Old 02-07-2017, 05:23 PM   #1
TinCup
TinCup's Avatar
Smile Zenith Carbs All Manufacturers
I picked up a Zenith Sidebowl top which allowed me to pair it with the Zenith 3 bottom I already had. After I got done I realized I now had all 3 manufacturers quite by accident. I currently have a Zenith 2 sidebowl on my late 31 deluxe coupe and this Zenith 3 will be it's replacement unless I decide to sell it. I found the Zenith 3 bottom 4 or 5 years ago.
TinCup is offline   Reply With Quote
Old 02-07-2017, 05:30 PM   #2
160B
160B's Avatar
Default Re: Zenith All Manufacturers
The Zenith 3 carburetor top is distinguishable from the others as they are a thinner casting and there is some reinforcement on the top ears.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 02-07-2017, 05:53 PM   #3
Rancho Deluxe
Rancho Deluxe's Avatar
Default Re: Zenith Carbs All Manufacturers
Sorry, That is not a Zenith 3 Top..
Rancho Deluxe is offline   Reply With Quote
Old 02-07-2017, 05:55 PM   #4
TinCup
TinCup's Avatar
It matches the 3 other Zenith 3's I have seen.
Old 02-07-2017, 06:18 PM   #5
Steve Plucker
Please continue your thought Rancho Deluxe as I to am interested.
Thanks.
Pluck
Old 02-07-2017, 06:26 PM   #6
Joop
Joop's Avatar
This is the best I can do
Top is different, picture from Standards page 1-15
Joop is offline   Reply With Quote
Old 02-07-2017, 09:51 PM   #7
Rancho Deluxe
None of the Carbs shown in Tincups pictures have the cast upper support under the mounting bolt hole in the one facing the rear of car as shown in Joops picture of the Zenith 3.. Both types of the 3s had that feature.
Old 02-07-2017, 10:02 PM   #8
160B
160B's Avatar
Here is a photo from the RG&JS page 1-15 revised 2016. Note the difference between the ears on the carburetor on the left hand side and the carburetor on the RH side. The one on the right is a Zenith 3.
Look closely at the areas circled in the 2nd photo.
Note for the carburetor on the left:
Zenith carburetor castings used from
January 1930 through April 1931. Note the
alternate design top casting with a "knob"
on the gas inlet passage.
Note for the carburetor on the right:
Typical Zentih-3 carburetor castings (flat
firewall style shown)
File Type: jpg zenith 3 carburetor croped_edited-1.jpg (39.1 KB, 122 views)
Last edited by 160B; 02-07-2017 at 11:16 PM. Reason: added photo with circled area of reinforcement area
Old 02-08-2017, 01:17 PM   #9
TinCup
TinCup's Avatar
Well I guess I have more looking to do. I have never seen a Zenith top like the one pictured above and I have seen my share of Zenith Carbs. I have seen a half dozen Zenith 3's and they all have the top I have now. I guess a half a Zenith 3 is better than no Zenith 3 at all
Old 02-08-2017, 01:27 PM   #10
JaxFLG8r
We rebuilt a side bowl carb for the late 31 truck. I am attaching the only picture I have on my phone. Angles and perspective are tricky, but it looks like the top pictured above. I know the bottom half is a Zenith -2. I will look closer at the carb when I go to the garage later tonight or tomorrow.
JaxFLG8r is offline   Reply With Quote
Old 02-08-2017, 02:17 PM   #11
Fullraceflathead
Fullraceflathead's Avatar
Many Original Zenith 3's Tops have cracked from 87+ years of use and abuse and are now sporting Tops from earlier Zeniths.
Remember the 3's were an early attempt at saving money by casting the walls thinner and the reason for the added bracing on the flange.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-09-2017, 12:17 PM   #12
Carb Guy
Carb Guy's Avatar
JaxFLG 8r Picture on the left looks to a Holley Zenith 2 side bowl correct top and bottom and correct for your late 31 truck
Carb Guy is offline   Reply With Quote
Old 02-09-2017, 12:24 PM   #13
TinCup
TinCup's Avatar
It is amazing how much lighter the Zenith 3 bottom is over the other 2. I wish I had a scale to weigh them.
Old 02-09-2017, 12:33 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
The post office might weigh it for you.
Of course the way they handle packages, they'll probably drop it and snap off the mounting ears.
Old 02-10-2017, 03:29 AM   #15
Capt Quahog
Capt Quahog's Avatar
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
There is a box out in the garage someplace with five or six ZENITH shape carburetors in it. Remember looking at them awhile back and none were marked ZENITH. Had a real ZENITH ONE pulled off the 31' Ford to compare those but got rid of that thing on eBay last year.
Does anybody actually use those clone ZENITH carbs? With other much better carburetors available, why would any manufacturer back in the old days have made a reproduction of the troublesome ZENITH?
I wouldn't be so paranoid if people weren't plotting against me all the time
Capt Quahog is offline   Reply With Quote
Old 02-10-2017, 06:33 AM   #16
jm29henry
jm29henry's Avatar
Good find Tin cup the coolest part is that the parts are interchangeable
jm29henry is offline   Reply With Quote
