Old 01-10-2017, 01:04 PM   #1
OL JENNY
OL JENNY's Avatar
Default Studs removed when removing Head Nuts
I am removing my head that was torqued repeatedly to 55# and stayed at 55# on repeated routine checks. When I removed it, 7 studs came out with the nut and only 7 nuts came off the studs. When I installed the studs 9,000 miles (2 Year) ago I did not use any sealant, just anti seize. I will be changing heads to a Snyder's 6:1 and am wondering if this is a problem with the studs releasing before the head nut, or if it is not an issue as long as the nut torques down and stays at the desired torque value. Thanks for your help.
OL JENNY is offline   Reply With Quote
Old 01-10-2017, 01:55 PM   #2
Dollar Bill
Dollar Bill's Avatar
Default Re: Studs removed when removing Head Nuts
Happens often. Torque readings are the same. You can put thread locker on the block end of the studs if you would like
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 01-10-2017, 02:03 PM   #3
TomballMottershaw
When removing a Head from the block... and the Stud comes out with the stud nut, I call that a Blessing. ;-)
TomballMottershaw is offline   Reply With Quote
Old 01-10-2017, 02:19 PM   #4
Pinesdune
Pinesdune's Avatar
Loctite retaining compound number 609 works good for an application like that, it's not as strong as a thread locker, but will stop the studs from corroding and leaking and help hold them in place when you remove the nuts.
Pinesdune is offline   Reply With Quote
Old 01-10-2017, 02:50 PM   #5
captndan
captndan's Avatar
Perfect excuse to replace the studs and nuts.
captndan is offline   Reply With Quote
Old 01-10-2017, 02:50 PM   #6
CarlG
CarlG's Avatar
Especially the 2 longer studs that hold the water neck.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-10-2017, 03:50 PM   #7
Synchro909
Synchro909's Avatar
I see loose studs as a problem. If the stud turns when you check the torque, the nut doesn't move on the stud. These two threads have different pitches. 55# torque on a nut that moves on the stud puts much more downwards pressure on the head than the stud moving in the coarser thread in the block does. I use a molybdenum anti seize on the tops of the studs and a sealant at the bottom where they go into the block. The nut moves when I retorque and the stud can be removed from the block without too much trouble.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 01-10-2017, 03:56 PM   #8
C26Pinelake
A new set of studs and nuts are insignificant as far as cost goes. Replace them all. Wayne
C26Pinelake is offline   Reply With Quote
Old 01-10-2017, 04:46 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
I would remove the nuts from the studs and clean and reuse the studs as long as they don't have pulled threads or are rust pitted. Use sealant on any studs that enter coolant.
