Old 01-05-2017, 09:01 PM   #1
Leonard
Default 1931 Model A Victoria Leatherback
I am about to install the new leather roof on my early 1931 Vicky and I can not find out what the front roof moulding looks like or where I can purchase it. I have what I think is the original, it is a 2 piece moulding 5/8 in. wide and seems to fit but the ends are rusted off and can not be reused. I beleve there should also be a clip that goes between the rain gutter and the moulding and also a clip that goes from the rear of the rain gutter to the hidem that goes around the back. I am hoping that someone knows what these items look like and where I can purchase them.
Leonard is offline   Reply With Quote
Old 01-05-2017, 10:15 PM   #2
kressej
kressej's Avatar
Default Re: 1931 Model A Victoria Leatherback
You might try the Victoria Association, I bet they have a tech article on it. I have a late 31, it had a thin Hartzcloth top with a metal strip across the front of the top. The Ford Service Bulletin has some original photos of a Vicky top replacement, check those out too. My new top has a hidem strip with arrow metal fasteners at the end. Let me know if you want some pix, I will be home by the end of next week.
Good luck - Joe
kressej is offline   Reply With Quote
Old 01-06-2017, 12:15 AM   #3
Leonard
I know that the moulding is a metal moulding not a hidem and I am almost positive that there should be a metal clip that joins the front metal moulding to the drip rail.
Old 01-06-2017, 12:29 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
There seems to be two for the leather back according to the guidelines,
Style F3,5/8" FRONT ALUMINUM 190-A (to 3/31) and
Style F5 5/8" FRONT ALUMINUM 190-A (after 2/31) including the steel back.
The trouble seems to be in the size. The F3 in the catalogs show the correct 5/8" but the F5 seems to sold in 1/2 inch only. (at least that is what Bratton,s has.)
Old 01-06-2017, 09:43 PM   #5
Terry Burtz, Calif
The F5 moulding being 1/2 inch wide is a catalog error.
The F5 moulding (A-163245-A2) sold by the vendors is 23/32 inch wide before installation. After installation and closing, the width becomes .640 inch which is close to 5/8 inch.
Terry Burtz, Calif is offline   Reply With Quote
