01-03-2017, 09:25 AM | #1 |
timing pin substitute
do any of you guys remember a substitute timing pin that was sold some years ago, that was spring-loaded, such that you did not have to unscrew the timing pin., merely press it on it till it fell into the dimple, then release?
did anyone ever buy it? does anyone still make it? |
01-03-2017, 09:37 AM | #2 |
Re: timing pin substitute
Only one I have seen is this one. Don't think this is what you are talking about.
http://www.snydersantiqueauto.com/timing-pin-tool-3669 |
01-03-2017, 09:42 AM | #3 |
never seen that accessory before! it is different because the thing I used to see was a permanent installation.
I suppose part of the theory was if you started the engine without removing the "fumble pin", as it was called in the old ads, it hogs out the dimple. |
01-03-2017, 10:16 AM | #4 |
I bought one in Hershey, made of brass. Well done and works as advertised. I don't leave it in the timing cover, just screw it into the cover when I use it, then replace the original timing pin when done. I found it in the chocolate field across from Tam's, but forgot the vendors name.
01-03-2017, 03:08 PM | #5 |
Yes, I've run one for years. I don't remember where I bought it and would buy an extra one if I saw them on the market. Sorry I don't remember, but it has worked great, never a problem
01-03-2017, 05:00 PM | #6 |
01-03-2017, 05:43 PM | #7 | |
1929 Model AA - Need long splash aprons! |
01-03-2017, 06:00 PM | #8 |
01-03-2017, 06:07 PM | #9 |
Sounds interesting,
Would someone be nice enough to post a picture |
01-03-2017, 06:38 PM | #10 |
01-03-2017, 06:45 PM | #11 | |
id post a pic but dont know the seller and wouldn't want to undermine his sales by people making thier own if someone remembers the name or has a contact others could buy from him that would be great! - I did hear snyders bought a whole buncha them to sell in thier catalogs - I dont know if the guy has caught up for that large of order or not :P
01-03-2017, 06:46 PM | #12 |
Haven't we all done that! Never clean up your workshop if you ever want to find stuff again.
01-03-2017, 06:58 PM | #13 | |
Timing is a cause of backfiring. I better check my timing. |
01-03-2017, 07:26 PM | #14 |
I,me with you 29& Tom
01-03-2017, 07:27 PM | #15 |
Alway shows up when your not looking for it!!!
01-03-2017, 08:10 PM | #16 |
Post #15: "Alway shows up when your not looking for it!!!"
_______________________________________ Yeah - but by the time you see it again , you don't remember that you were ever looking for it ! |
01-03-2017, 09:06 PM | #17 |
I'm finding this thread very comforting. I'M NOT ALONE!!
01-03-2017, 11:06 PM | #18 |
Put the pin in with rubber bands holding it in. Hand crank slowly using both hands and watch the pin slip into timing dimple then STOP ! You got it . Throw away the rubber bands cause you Won't remember where there are. Always change rubbers as needed.
01-03-2017, 11:12 PM | #19 | |
That's what my dad told me |
01-04-2017, 05:12 AM | #20 |
