Old 12-29-2016, 09:01 AM   #1
JohnB15632
JohnB15632's Avatar
Default 31 Model A SW Town Sedan Project -Roof wood header
Does anyone know if there exists the original drawing for the roof wood header? I am trying to modify the header that came with the car.
It obviously if not configured correctly.
JohnB15632 is offline   Reply With Quote
Old 12-29-2016, 11:30 AM   #2
art ebeling
art ebeling's Avatar
Default Re: 31 Model A SW Town Sedan Project -Roof wood header
Did you remove the doors? How were the gaps at the doors? I would think that your doors would have to be on with correct gaps before you would know where to nail the roof side panels and then see how the metal header cover fits against the end of those roof side panels. Also, Is the body still on the frame?
art ebeling is offline   Reply With Quote
Old 12-29-2016, 11:34 AM   #3
JohnB15632
JohnB15632's Avatar
My problem right now is that the wood header is wrong. I can not install the front cover correctly. I need to cut down the wood header before I can get to any other aspect of the reinstall.
I can not secure any metal parts until this one aspect is fixed.
Old 12-29-2016, 11:43 AM   #4
art ebeling
You once mentioned using a router. I would try a belt sander and start at both outside edges if you think the metal cover is not going on far enough. I would still like to know about the door fit. I had the same situation on my Victoria because the metal body shell was not forward enough on the body wood. When that was corrected and the door gaps right the header and side panels were up against each other.
Old 12-29-2016, 12:30 PM   #5
art ebeling
This is how mine ended up. Notice where the gutter ends in relationship to the pillar. I mentioned before yours looks too far back.
Old 12-29-2016, 02:55 PM   #6
JohnB15632
JohnB15632's Avatar
I received this body without the doors installed. I do have all four doors, at some point I was going to install the doors, alone with the fenders, and aprons. Dry fit everything.
I just feel that the front wood header problem must be resolved first before trying to hit the doors and securing the skin to the header wood.
The wood header is way, way off. As currently configured, if I push the cover onto the header, there is almost 3/4 inch gap between the cover and the side metal. That is why I am concentrating on the wood header.
I do not have a band sander. I only have a router. I can use this router to remove wood a little at a time. I am taking my time with this.
May you all have a Blessed and Happy New Year!!
John
Old 12-29-2016, 03:55 PM   #7
Bruce
Bruce's Avatar
One of the early Restorer Magazines -- 1966 maybe -- had a drawing included. I think the issue had a drawing of a Victoria. That's as far as my total recall (which has been recalled) goes.
Bruce is offline   Reply With Quote
Old 12-30-2016, 12:09 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
Harbor Freight has an air operated little band sander that would likely be very useful for this job. I think I paid about $25 for mine. I bought the heavy electric one first, but returned it the next day for the air one. The electric one is too big and clumsy.
Old 12-30-2016, 08:29 AM   #9
Mitch//pa
If it was me i would have departed with the 156.00 and bought the proper one from classic wood...
There may be other differences that you are unaware of...
Do it once and do it right... its a tiny setback in the overall scheme of things
Good Luck
Old 12-30-2016, 09:47 AM   #10
JohnB15632
JohnB15632's Avatar
Thank you for the advice. I do appreciate you help.
As I know that you are an expert on Model A restoration, I have taken your advise and ordered to new header from Classic.
Thank you,
May you have a Blessed, Prosperous, Healthy, and Happy New Year!!!
Old 12-30-2016, 11:52 PM   #11
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Is it the same header as the Victoria?
Old 12-31-2016, 12:18 AM   #12
jw hash
jw hash's Avatar
also when you get the header from classic wood. you will have to sand and fit it to the cover. you want a good and tight fit on the ends or when you nail the panels to it and install the molding, you need the wood right under the panels.
jw hash is offline   Reply With Quote
