Old 12-09-2016, 03:50 AM   #1
Chris Van
Chris Van's Avatar
Default Ammeter shows discharge but not charge
Hi Boffins
Please help:
I use my car as a daily driver in the Johannesburg traffic, but using it at night has become a huge problem as the battery does not charge up enough, so every time I get home I have to connect my 6v charger up so that the car will start in the morning.
Am going to give it a go to adjust the charge rate on the generator by apparently moving the "3rd brush" (whichever the hell that one is) clockwise...
But the other problem is that my ammeter is showing discharge, but not charge... it stays on zero when I am driving. But the genny must be charging otherwise my battery would be running down real fast.
Any help with this will be hugely appreciated.
Chris Van
Chris Van is offline   Reply With Quote
Old 12-09-2016, 05:14 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Default Re: Ammeter shows discharge but not charge
Swap the wires on the meter and see if it will go the other way to eliminate the meter as the problem.
https://www.fordbarn.com/forum/showthread.php?t=3122
Old 12-09-2016, 08:30 AM   #3
eagle
eagle's Avatar
Before doing that, Take some voltage readings and get back to us. Then we can give you some feedback. 1. Voltage at battery when engine off, also with engine at a fast idle. 2. Voltage on both sides of the cutout with engine running at the same fast idle. 3. Fast idle again, check voltage at battery with lights on.
Ignore the underlined words, for some reason when I use this computer I get random words underlined.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 12-09-2016, 10:36 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Key words used in the SEARCH feature are underlined, and misspelled words are underlined by spellcheck. Aside from these two reasons, I've also seen random times when a few words get underlined, and I have no idea why. Of course when it comes to computers, I'm no good.
Old 12-09-2016, 11:34 AM   #5
eagle
eagle's Avatar
Don't know whats going on with that, an hour ago the underlining was there, now its gone! Whatever...
Old 12-09-2016, 05:17 AM   #6
Chris Van
Chris Van's Avatar
Okay Mike thanks will do that....
Old 12-09-2016, 08:40 AM   #7
Patrick L.
Patrick L.'s Avatar
Turn the lights on, or, just step on the brake pedal and see that the ammeter shows discharge. It should and then you'll know the ammeter is connected correctly.
When running normally with lights off does the ammeter show any charge ? It should a few amps. If so, then adjusting the third brush for more charge should take care of your problem. Adjust it for about 8-10 amp charge without the lights on. I don't like to see these generators set at more than 10 amps.
Old 12-09-2016, 08:42 AM   #8
Mitch//pa
Posts 4 & 5 got it right
Old 12-09-2016, 08:49 AM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Try POLARIZING the generator.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-09-2016, 11:36 AM   #10
Steve Plucker
Bill W.
Right on William!
Pluck
Old 12-09-2016, 09:37 AM   #11
Mitch//pa
Diagnose and verify before moving and adjusting
Old 12-09-2016, 10:31 AM   #12
Chris Van
Chris Van's Avatar
Thanks Mike, Eagle.
Okay I have an appointment at a buddy with a multi-meter on Monday and will do all the testing.
Will keep you posted.
Good weekend,
Chris
Old 12-09-2016, 06:41 PM   #13
ian Simpson
Originally Posted by Chris Van View Post
Hi Boffins
Please help:
Chris Van
Not so. If your motor starts up really fast there is minimum drain on the battery and you can run for many days without a charge if not using your lights.
When we bought our Model A it had a duff generator but ran for over a month before letting us down. (I thought we had a bad ammeter, did not make the necessary checks)
Sounds like your generator, cut out/voltage regulator are not working correctly. Take the voltage readings as recommended above and report back.
ian Simpson is offline   Reply With Quote
Old 03-13-2017, 06:19 PM   #14
Chris Van
Chris Van's Avatar
Hi Guys
Thanks a billion for your comments. I was driving from Johannesburg, to Clarens (about 200 miles away) for to do a wedding and driving at about 55 to 60 mph (I do have the tall diff) but the oil level was only half and maybe if it had been full I would not have run big end #4! So there is this Model A boffin called Kevin Casey, who lives in Harrismith, who collected my car on a trailer (lucky we organized a substitute car for the wedding.. a '48 De Soto)... and when it was fixed he noticed my electrical problem... and Ian Simpson you are 100% correct... I had the points-type cutout switch but he said the points were not closing and the reason my battery was not dying because yes my car starts real quick and I charge it manually for night driving... but the points by natural vibration when you are driving do touch, sending a sliver of power to the battery. Anyways, Kevin chopped off the whole points thing and soldered in a nice fat diode (30A) and voila! it now charges like a wounded buffalo. He said the diode should last the life of the car provided I don't get the battery polarity wrong. Apologies for taking so long to reply but I had no way of sorting this out myself until the bearing went and the car got into the right hands. Btw I have joined the Model A Club of America. Thanks again guys and please don't see my tardiness in replyin as a lack of respect... I was at my wits' end and had nobody who wanted to touch the car because it is 6V.
Old 03-11-2018, 01:31 PM   #15
Floats
Floats's Avatar
Replying to post #14
KEVIN CASEY is a CHAMPION. Not only Model T and Model A, but an allround champion and a gentleman. He is a much respected and loved in the South African old car community.
Chris
Mossel Bay
Floats is offline   Reply With Quote
Old 03-13-2017, 06:31 PM   #16
SeaSlugs
SeaSlugs's Avatar
Cool glad to hear you got it figured out. and yes the diode is a magical thing and cant really get stuck. Thanks for reporting back what you found and your fix was! Far too often we are left in the dark
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 03-14-2017, 05:23 PM   #17
Chris Van
Chris Van's Avatar
All good, SS!
Old 03-17-2017, 03:19 PM   #18
rtruax
I had this same problem with my cut out. The Amp Meter showed discharge but never charge. I drove about 20 miles last fall and almost didn't make it home due to low battery. I took the cover off the cut out and observed that it was not closing when the car was running. When I closed it manually ( a sliver of wood) my amp meter showed charge. I installed a new cut out and no more problems.
rtruax is offline   Reply With Quote
Old 03-09-2018, 07:58 PM   #19
scott62
scott62's Avatar
Just installed a newly rebuilt generator. Getting "no" increase in amps on ammeter even after sliding the "middle' brush to its max in either direction. I assume the 3rd brush is the middle brush. Its the brush on the top when removing the cover. I know the ammeter is good. I get a discharge when I turn the lights on and it goes back to 0 (maybe even 1 amp positive). New 6 volt battery fully charged....6.3 volts reading on the output terminal of the (new solid state) cutout switch at fast idle. With 6.3 vdc (Fluke Multometer) you would think that I'd get a higher reading that 1 amp ximim on the ammeter. Ideas?
scott62 is offline   Reply With Quote
Old 03-10-2018, 09:32 AM   #20
Tom Wesenberg
Is your new cutout the one with a built in voltage regulator?
If it's just the diode regulator, then make sure the battery is installed with the correct + ground, and be sure to polarize the generator by applying 6 volts to the generator output post for 1 second. Just jump across the two cutout terminals for one second to polarize the generator.
