#1 |
![]() City:
Los Angeles
State:
CA
Price:
20-100
Model A spare tire mount-$30
32-42 Ford flathead standard piston rings 4 ring-$70 32-42 Ford flathead .030 over piston rings 4 ring-$70 37 Ford flathead exhaust manifolds-$20 23-25 Model T top brackets-$20 37 Ford flathead oil pump-$20 Hildebrant oil filter-$150 37 Ford flathead intake-$20 37 Ford flathead generator/fan-$100 48-53 Ford truck fan-$30 2 16" Ford wire wheels-$100 36 Ford torque tube-$100 37 Ford flathead camshaft with cam gear & lifters-$100 37 ford flathead water pumps-$50 48-53 (I think) Ford flathead oil pickup-$10 37 Ford flathead crank pulley & nut-$45 Photos can be seen here. <iframe width="480" height="360" src="http://s137.photobucket.com/user/chops93typhoon/embed/slideshow/For sale"></iframe> Everything should be pictured there, but if the item you are interested in was missed, let me know, and I will get photos. A friend of mine also has a '38 transmission for sale, and a 40-7222 shifter tower, with shift lever and forks, but forks have been ground to fit a '39 trans |
