Old 11-16-2016, 09:18 PM   #1
TNDoug
Default R-10 Overdrive update
I had a lot of suggestions to help solve the governor gear not spinning with the shaft. I ended up having a machine shop cut a keyway in the shaft and the governor gear to match. The owner did not want to take a chance of it not working when it was in the car (again). I believe that the overdrive assembly was put together with spare parts. There were no diagrams that matched what I had. The job ended up at my shop because no one would work on it. It looks great and went together fine. Thanks to all of you for responding.
TNDoug is offline   Reply With Quote
