#1 |
I have the Double D tool to remove the nut and I've blocked the gears with a piece of wood but the gear just keeps losing teeth as I spin it. Any suggestions on getting this thing off?
#2 |
Impact wrench
www.whidbeymodelaclub.com |
#3 |
Looks like I'll be removing the radiator. Was hoping to avoid doing that. Damn.
#4 |
Rather than a block of wood, try a shop rag.
#5 |
The block of wood is a no no .Do as Patrick says use the wifes best heavy towel and stuff it in ,spreads the load on the teeth ( as the actress said to the bishop )
John in cool dark roll on sunny Chandler AZ Suffolk County England |
#6 |
As Forever 4 indicated use a good 1/2 impact and give it some bumps, hopefully it will loosen up. When re-installing make sure your timing marks are aligned. and spring and plunger re-installed |
#7 |
Lefty loosie,, righty tightie
#8 |
#9 |
#10 |
Before pulling the rad, you might trying vice grips on the cam gear, resting them against the pan to keep from turning. Impact wrench will definitely work.
#11 |
Hammer and flat ended punch.
#12 |
Impact was the answer. Thx.
