Old 10-26-2016, 11:26 AM   #1
40cpe
40cpe's Avatar
Default fuel pump flex line
What size tubing and type fitting screws into the inlet side of the fuel pump flex line? My fuel line has been replaced with a 5/16" steel line. I need to adapt it with the correct end to fit the rubber line to the fuel pump. 1/4" or 5/16"? Flared or ferrule? Thanks, Gene
40cpe is offline   Reply With Quote
Old 10-26-2016, 05:14 PM   #2
G.M.
Default Re: fuel pump flex line
The steel line from the tank has a brass ferule 2 with a male 1/2-20
thread. This screws into the female 1/2-20 on the flex hose. I would
find or make an adaptor to get back to an original flex hose. Bob
Shewman makes the best hoses available. Call him at 1-610-933-6637
and he could make an adaptor or put a female fitting on the hose to
match the end on your fuel line. G.M.
www.fordcollector.com
Old 10-26-2016, 06:52 PM   #3
40cpe
40cpe's Avatar
Thanks G.M. That is what I needed.
