10-16-2016, 11:10 PM | #1 |
1937 Ford carburetor
I have a 1937 Ford 85 hp with a Stromberg 48 carburetor which someone added along with what I am assuming is not original, a 1/2" carb to intake spacer with vacuum port. Since I do not need the vacuum port does anyone know if I can just remove the spacer or is it needed?
10-16-2016, 11:23 PM | #2 |
Re: 1937 Ford carburetor
Does your '37 have a two-speed rear-end aka a Columbia Overdrive? If not, removing the spacer will not cause a problem....
10-17-2016, 07:09 AM | #3 |
the mounting studs will be long but they can also be changed. Many of the hardware stores carry the proper stud.
10-17-2016, 08:45 AM | #4 |
No two speed rear end. I have also noticed that some people place an extra tall spacer under the carb, is that for keeping the carb cool?
10-17-2016, 10:07 AM | #5 |
The original carburetor for a 85 hp '37 was a 97, not a 48.
10-17-2016, 11:30 AM | #6 |
10-17-2016, 11:59 AM | #7 |
Was there originally any spacer between the carb and the intake or just the gasket?
10-17-2016, 12:00 PM | #8 |
Just a gasket....
10-18-2016, 12:07 AM | #9 |
That may have been for a Marvel Mystery Oiler or Ampco oiler.
I dig coal, which provides motivation for EVs. |
10-18-2016, 01:32 AM | #10 |
Just leave it unless it really worries you..
10-18-2016, 09:57 AM | #11 |
Thanks for your input.
10-18-2016, 10:09 AM | #12 |
Could the spacer be a left over part of a Southwind Gas Heater set up?
10-18-2016, 12:27 PM | #13 |
I would suppose if so there would be a cut out in the firewall?
10-20-2016, 11:29 AM | #14 |
I pulled the carb, so I got a pic of the spacer.
10-21-2016, 02:02 AM | #15 |
Certainly looks like a southwind vacuum plate.
Martin. |
10-21-2016, 07:05 PM | #16 |
Thanks
10-21-2016, 07:55 PM | #17 |
Cave,
Don't loose that South Wind plate it's quite saleable. Charlie ny |
10-22-2016, 11:09 PM | #18 |
Will make note of that, thanks Charlie
01-02-2019, 05:06 PM | #19 |
Looks about same size pipe as the Columbia OD needs.
I need one. |
01-03-2019, 09:13 AM | #20 |
After the war, Ford used this location for the vacuum for the wipers. I think the wiper works better getting vacuum at this location instead of between two intake ports.
