#1 |
Currently building a front end to go under my car and needing some direction as to the correct number and style of leaves used on an original 32. I have three different spring pack from under 32's and none of them are the same other than the main leaf. One has 14 leaves, one has 10 and the other has 8. Each has a mixture of square cut leaves and taper cut.
Any explanations or good pictures of an original front spring would be greatly appreciated. Thanks, Don |
#2 |
