Old 10-09-2016, 01:14 PM   #1
sphooch
sphooch's Avatar
Question 31 rdster wiring help
Hi guys, I'm installing the wiring in my roadster. the car when I got it didn't have any at all so its all new to it and me. the first question was the bail wire installation ,got that solved thanks to you guys. but a problem happened at the sw. box, the inside piece with the 3 dimples flew apart because I removed it incorrectly . the brass ring with the small spring and small brass inner washer popped out. I reassembled it but it can go back together 2 ways. i can orient the dimples at 1- 5 & 9 o'clock or 11- 3 &7 o'clock. with the dimples at 11-3 -7 position I have this : move the sw handle to the left and one wire to the head lite gets power, move the switch one position to the right and it shorts out the fuse . I'm gonna try to change the small brass ring inside the switch to the 1-5-9 position . its a lot so before I tackle it does any know for sure the proper position of this part of the switch?? question # 2 are the parking lites and the cowl lites considered the same lites. my manual says moving the switch to the left turns on the parking lites and no mention of the cowel lites . THANKS FOR TAKING THE TIME TO HELP ME OUT THE HOOCH
sphooch is offline   Reply With Quote
Old 10-09-2016, 02:01 PM   #2
Bob C
Default Re: 31 rdster wiring help
Tom had posted this picture. I don't know if it will help you.
Bob
Old 10-09-2016, 05:48 PM   #3
sphooch
sphooch's Avatar
yes, thank you . from the pic. I see that 1-5-9 is the orientation I need. thanks a million. THE HOOCH
Old 10-09-2016, 10:20 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Originally Posted by sphooch View Post
Question # 2 are the parking lights and the cowl lites considered the same lights. my manual says moving the switch to the left turns on the parking lights and no mention of the cowl lights .
Low power lights that were used to park the car without shining brighter lights into traffic could be a bulb in the head light or cowl lights.
Old 10-09-2016, 10:27 PM   #5
Mitch//pa
Originally cars with cowl lights had 1 bulb headlights.....cars produced without cowl lights had 2 bulb headlights. And yes turning the light switch to the left would activate whichever it was equipped with...
