Old 10-03-2016, 06:32 PM   #1
ed mazzola
Default Oil in 9'' rear end
Oil to use in rear end an how much 9' rear.
Ed
ed mazzola is offline   Reply With Quote
Old 10-03-2016, 07:21 PM   #2
Drbrown
Drbrown's Avatar
Default Re: Oil in 9'' rear end
Lots of opinions/recommendations here. "Search" rear end gear oil.
Personally I use StaLube 140w even tho I'm in a cooler climate. Could use lower viscosity (i.e. 90w) but it may increase gasket/seal leakage if you have such. Fill to plug level.
Drbrown is offline   Reply With Quote
Old 10-03-2016, 08:13 PM   #3
paul2748
paul2748's Avatar
90 weight should do the trick in a later (57 up) 9 inch rear. Fill to fill hole.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-07-2016, 06:55 PM   #4
ed mazzola
Do i use any synthetic or just use 90w gear lube.
Thanks
