Old 10-03-2016, 12:46 PM   #1
rosenkranswa
rosenkranswa's Avatar
Default Leaky Carb
Just cleaned two carburetors. One went back on fine and is working beautifully, the other now has a bad gas leak both with the engine running and not. Leaking from underneath and from the intake port. Checked all the connections for tightness.
Guessing that the float valve is stuck fully open either because of dirt or possibly a sunk float. Would it continue to leak from the intake with the engine running though, even with a stuck float valve?
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'38 Columbia Girls bike (WWII)
'40 Elgin Boys bike (WWII)
'42 Super Deluxe Tudor
'42 Willys MB Jeep
'43 Willys MBT Trailer
'43 M3A4 Hand Cart
'43 Harley Davidson 42WLA with sidecar
rosenkranswa is offline   Reply With Quote
Old 10-03-2016, 01:11 PM   #2
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Re: Leaky Carb
Sure it can. There is a lot more fuel coming into the bowl than your engine can use. Check the gaskets under the jets. I bet one is missing.
Jacksonlll is offline   Reply With Quote
Old 10-03-2016, 01:22 PM   #3
rosenkranswa
Didn't remove the jets to clean, just blew carb cleaner through everything so all gaskets on the jets should still be there.
Just pulled at apart again and blew some cleaner around the float valve and float, checked for obvious crud, and put an a fresh gasket. No joy I'm afraid still leaking badly.
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'42 Willys MB Jeep
'43 M3A4 Hand Cart
Old 10-03-2016, 05:15 PM   #4
Big hammer
Maybe some of that crud was sealing a pin hole or crack
Old 10-03-2016, 06:22 PM   #5
larrys40
Sounds like needle and seat or float is sticking .
It's overtopping the cap and main jets which is why it's coming out the throat
Check float action and needle and seat
Hopefully easily resolved
Larry
larrys40 is offline   Reply With Quote
Old 10-03-2016, 06:25 PM   #6
Mike
Mike's Avatar
Wayne we will try and get together after hershey
Mike
Mike is offline   Reply With Quote
Old 10-03-2016, 09:49 PM   #7
JerMar
JerMar's Avatar
Mine was doing same thing and I took apart and checked the float, then I added another washer to the float valve and it stopped.
JerMar is offline   Reply With Quote
Old 10-04-2016, 10:03 AM   #8
rosenkranswa
When you say you added another washer, do you mean another gasket under the float valve?
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'42 Willys MB Jeep
'43 M3A4 Hand Cart
Old 10-05-2016, 06:32 AM   #9
merrbarb
Smile Re: Leaky Carb
Hello Wayne: Boy can I relate to your leaky carb problem. Took my carb off -and on - three times each time blowing out, using carb cleaner, setting the float height, taking out the float valve each time and throughly cleaning, cleaning the filters, and the carb still leaks. Maybe I'm stubborn but I still think the problem is with the float valve. So I ordered the "modern" valve from Bratton's, the one with the Viton tip and will install that in another day or two, then see what happens.
Or I just may get to meet you at Mikes in Aston for a carb party, which is always a good thing anyway.
merrbarb is offline   Reply With Quote
Old 10-06-2016, 03:30 PM   #10
rosenkranswa
The latest - Took carb off and on several times; 1st time to repeat all cleaning steps, still leaking badly; 2nd time took float valve out (newer ball bearing type) examined with a magnifier but couldn't see anything so thoroughly cleaned and reassembled, still leaking badly; 3rd time (after seeing Mike at Hershey) put another gasket under the float valve, took a lot longer but did finally start to leak. Started the engine and the leak stopped, adjusted the GAV, idle RPM and idle mixture to spec. and everything is running beautifully. Turned the gas off and let it die, will check again tomorrow.
So the extra gasket did something, but not a complete cure. All the cleaning certainly had a major effect on the poor running I was seeing though. Like Merrbarb, starting to wonder if a new float valve of the original design (viton tipped) might be indicated.
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'42 Willys MB Jeep
'43 M3A4 Hand Cart
Old 10-07-2016, 04:53 PM   #11
Brentwood Bob
Also might do a test on the float. Could be the float starting to loose buoyancy. The contact point between the float valve and float can also create a wear point on the float that can cause the float valve to stick.
Bob
Brentwood Bob is offline   Reply With Quote
Old 10-07-2016, 05:45 PM   #12
rosenkranswa
Checked the float when I had it off and it seemed OK, that is to say floated fine in a jar of gasoline overnight. Also checked the height which checks at 5/8. Its just about got to be something slightly off with the float valve. At least its driving very well again, and I usually turn the gas off when I stop anyway.
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'42 Willys MB Jeep
'43 M3A4 Hand Cart
Old 10-07-2016, 07:43 PM   #13
redmodelt
redmodelt's Avatar
To check a float; bring a pan of water just up to before the boiling point. Submerge the float and look for bubbles escaping from it. Just floating in a jar of gas isn't going to tell you if it leaks.
The extra gasket moves the gas level in the bowl down. You are setting the gas level for the jet at or just below the tip where the surface tension will keep it from weeping over and out the jet.
Old 10-08-2016, 10:11 AM   #14
Brentwood Bob
Found this in my notes from past fordbarn threads:
to avoid weeping when engine is stopped:
the top of the main jet should be 3/64" - 1/8" above the top of the cap jet.
look for improper length: main jet (#20) 1 15/32" from tip to head(gasket face),
cap jet (#21) 1 5/32" from tip to gasket face.
Also look in the casting to remove any extra gaskets lurking.
Bob
Old 10-08-2016, 06:50 PM   #15
Carb Guy
Carb Guy's Avatar
More than likely the float valve, not a good one made today. Some work most do not.
Carb Guy is offline   Reply With Quote
Old 10-08-2016, 08:42 PM   #16
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
The latest - Took carb off and on several times; 1st time to repeat all cleaning steps, still leaking badly; 2nd time took float valve out (newer ball bearing type) Like Merrbarb, starting to wonder if a new float valve of the original design (viton tipped) might be indicated.
The original is a ball bearing style, and the viton is newer style invented in the late 50s I believe. There is another newer style with two balls and a o ring seat.
Guess I'm lucky as the original ball style works great for me.
If you haven't checked yet, look at where the float rubs on the valve. Wear will cause a hang up.
Old 10-08-2016, 11:07 PM   #17
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by Chuck Sea/Tac View Post
The original is a ball bearing style...
I've had good luck with the "Original Style Float Valve" https://www.brattons.com/original-st...oat-valve.html from Bratton's. I don't believe it is a "ball bearing style" tho.
Old 10-09-2016, 10:35 AM   #18
katy
katy's Avatar
[QUOTE]Originals valves were needles, not balls./QUOTE]
Ditto
