#1 |
I recently had trouble trying to install a newly purchased switch from Mac's because it was to deep. I have a very early canadian 28 tudor that seems to have many differences than other early 28's. I found a switch from WAYTEC INC, Chanhassen MN 55317 that fits perfectly.. I've included the specs for this switch. I hope this might help others with this problem.
#2 |
Since nobody will reply, I guess I will...Thank you for the tip.
I had issue with a switch myself, they can be a booger.
#3 |
Thanks for the info. I hadn't heard of this supplier but I do get to Chanhassen occasionally. I will have to check it out.
Is this the switch? https://www.waytekwire.com/item/4417...ition-Switch-/ |
#4 |
Yes that is the switch in post # 3 and no I did not have to alter the hole in the dash either. It is good value for the switch.
#5 |
The link posted above says it needs a 3/4" hole.
Bob |
#6 | |
It is a possibility that they will re source the switch to the one you mention if enough people let them know of problems.
#7 | |
![]() Quote:
I wouldn't screw up original parts to make a misfit part fit. |
