#1 |
Over the weekend a good friend and I drove my 53 Ford 350 miles to the coast. On our way, I noticed the car was loosing a little power on grades. It got worse and worse, would just bog down and only wanted to idle...wanted to die if you gave it gas. About halfway there I stopped by a friends house who had a used fuel pump. We installed it and went on our way. Car did great until reaching our destination...pulling into town it started doing the same thing. We looked the car over and saw nothing obviously wrong
Returning home, we made it about 70 miles before it started acting up. Same symptoms only now it was doing it more and more. Just before a major mountain pass, I decided to check the float levels (dual carbs). They were low, so I adjusted them and made it a few miles before the problem returned. It did barley make it up the pass, coasted down but struggled the 15 miles before the next town. Car would only run at idle or if I barley feathered the throttle. Any more throttle and it would want to die. I'm picturing just enough fuel getting to carbs to let it idle. In town, I bought a 6 gallon gas can and the last 9 feet of fuel line they had. Rigged it together and the car sailed the 180 miles home with out a hiccup doing 65 MPH So, I presumed plugged gas tank or line. The entire fuel system is only a year old, the tank was cleaned, rebuilt pump, carbs and all fuel line replaced (except about 2 feet where it goes up over frame...I think the body has the be removed to replace that portion) But, to my disappointment the tank looks new inside, I blew backwards through the pickup and when looking in the tank see nothing coming out and air rapidly blows through. I had my wife use the compressor to blow the fuel line from under the hood, while I watch under the car. Again, plenty of air passes and nothing came out of the line that could have obstructed it. So I'm baffled. I did pull the push rod and the fuel pump end is worn...although I'm not sure if it's enough to do anything. I think I'll try a new pump, push rod and install a 6V "backup" fuel pump on the car and try that. I sure hope it's not the cam lobe going flat. Does anyone else have any ideas or suggestions? ![]() ![]() ![]() ![]() ![]() ![]()
Thee Inland Emperors |
#2 |
Might be a bad batch of gas. Did the car run fine before the last fill-up? For how long? I've had this happen to me.
#3 |
Not any help, but just want to say. That is a nice car!
#4 |
How close to the exhaust is the fuel line? If the gas is boiling it could be the problem.
Greg |
#5 |
If the steel pickup line inside the tank has a leak in it above the fuel level then the fuel pump will be sucking air.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 09-28-2016 at 06:10 AM. |
#6 |
It is highly unlikely that the cam lobe went flat - but you can easily check the pump-rod action when you have the pump off the intake. Good Luck! |
#7 |
Don't overlook the possibility of the fuel cap creating a vacuum in the tank.
#8 |
#9 |
#10 |
If it pumped alright from your gas can, that would seem to eliminate the pump as a problem. I too would look at the tank vent.
#11 |
What about the rubber flex line to the fuel pump? They give lots of problems when they go bad.
Rob |
#12 |
This happened on our RV and the contaminated fuel filters ended up restricting the fuel flow with loss of power symptoms exactly like yours. We ended up having to replace both the sock in the gas tank and the secondary fuel filter in the line between the tank and engine.
#13 |
Since the extra fuel tank solved your problem. the pump is probably OK. Did you hook up the new tank line to the flex line or the fuel pump? If you attached to the flex line, that is probably OK also. I would think that you have trash in the gas tank that floats around and plugs up the intake. Remove the tank, tilt it back toward the fill tube (is the fill tube removable). slowly pump gas into the tank and look into it with a flash light while moving the tank back and forth. Hopefully you will see foreign object(s) floating by and that should be your problem.
#14 |
According to a gas cap catalog I have 1953 Ford used a non-vented cap
so check the tank vent. Bob |
#15 |
A quick check is to run it with the cap off.
#16 |
Thanks for the response guys!
First off- I do not think it's bad gas as we filled up several times during the trip I do not think it is the tank, I drained it through a paint strainer and although there was a few particles of dirt, not very much. I did remove the gas cap while running rough and it was not sucked on so I left it (It was raining so I did not want tater getting into tank), although a test with it off could have proven something. I did have the vent off the tank when I cleaned it, I will check it again There are two rubber flex lines on the car- both new and E85 approved...but I will replace both. The only reason I think it may be the pump still is maybe with the can behind the seat it is not having to work so hard? It's not pulling the fuel as long or around curves? Maybe that's a wrong thought, but one I had. The pump in the car is one I rebuilt, I think I will put a new pump on (35.00 from Rock Auto for a Carter) just for peace of mind. So, I think I will double check the tank (The hole in pickup tube is a great idea I did not think to check for...still do not know how I will do that), check vent, doucle check entire line and all connections, replace both rubber flex lines, and new fuel pump puch rod. Aside from the fuel pump lobe on the cam, that should cover everything. I don't mind throwing a little money at it, I just want a good reliable car. I took this car on this trip because I thought it was my most reliable and comfortable, HAHAHA
#17 | |
![]() Quote:
Chris: Not old Ford related, but kind of fuel pump related. I had a '85 Jetta GLI that was giving me fits. Similar scenario: Idled great, but when you got on it, it would die. All tests at idle showed the pump working as it should. When "under load" is where the fuel pump issue was really happening. Now carbs, F.I. mechanical and electric pumps are worlds apart, but I'm leaning toward your pump being the issue as well. So, from all you've said you've done to the car and it's symptoms, I'd say it's the pump as well. It's hard to test a the pump while you're driving down the road. I guess the one way would be to install an electric pump. If that solves the problem, it would point to an issue with the fuel pump working correctly under a load problem. |
#18 |
A fuel gauge would help see what is going on, but might not be worth the effort.
#19 |
As in a pressure gauge?
#20 | |
![]() Quote:
