Old 09-17-2016, 09:44 PM   #1
oldrelics
Default What to use for truck running board paint?
I want something somewhat durable to stand up to a little footwork anyway.
What did you use and hows it holding up?
oldrelics is offline   Reply With Quote
Old 09-17-2016, 10:03 PM   #2
Scott H in Wheaton
Scott H in Wheaton's Avatar
Default Re: What to use for truck running board paint?
Not sure how it is going to holdup yet, but my '36 running boards are sprayed with a couple coats of Ace Hardware Black Epoxy Appliance Paint. Glossy, but not like show-car over-restored glossy.
Scott H in Wheaton is offline   Reply With Quote
Old 09-17-2016, 11:42 PM   #3
FortyNiner
FortyNiner's Avatar
I used POR 15 five years ago and it has held up well.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 09-18-2016, 12:11 AM   #4
oldrelics
Do you have any pictures?
Old 09-18-2016, 01:47 AM   #5
Ray Balukas
Ray Balukas's Avatar
I used Sems Rock It Bedliner. Get the tintable if you want to color match, your paint store can mix the paint with no binders. Ray
Ray Balukas is offline   Reply With Quote
Old 09-18-2016, 02:46 AM   #6
cretin
cretin's Avatar
Personally, If I planned on using running boards for the intended purpose, I would cover them in rubber, or at least where you are going to step in rubber with some kind of trim around it. Will wear better then paint, but thats just an opinion.
cretin is offline   Reply With Quote
Old 09-18-2016, 07:05 AM   #7
oldandtired
If you want to drive the vehicle and not have to worry when someone steps onto the running board and twists their foot as they enter the cab to sit down, I would recommend that you use one of the quality spray-on bed liners. They come in everything from the really rough texture Rhino to a relatively smooth finish like Linex. I do not know which year vehicle you are working on, but I believe the 35-37 pickups were pretty much just black running boards. POR is amazingly durable for a gloss black, but it seems like the early POR was not UV friendly...perhaps they make a UV resistant formula now. If you use POR, be careful because it is the Dickens to clean up if you spill some.
oldandtired is offline   Reply With Quote
Old 09-18-2016, 07:26 AM   #8
chap52
chap52's Avatar
I find that Rustoleum Engine paint is very durable. But with the foot traffic you might consider doing the step area with one of those bed liner paints already suggested. A combination with just the top done with the more durable step liner in lieu of rubber matting would look nice and last awhile. Either that or have everyone remove their shoes before entering. Next post will be about "strange odors" in the cab..
chap52 is offline   Reply With Quote
Old 09-18-2016, 08:43 AM   #9
rotorwrench
rotorwrench's Avatar
Epoxy paint is the most durable but it is not UV resistant at all plus it's not easy to source now days. Polyurethane is tough stuff but it has to cure for a good period of time to come to it's greatest hardness and be chip resistant. A lot of folks use the accessory step plates to step on directly but others view them as somewhat gaudy.
Old 09-18-2016, 09:22 AM   #10
waterboychuck
waterboychuck's Avatar
You might want to look at Valspar tractor paint. You can roll it on, brush it on, or spray it on and it will last.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 09-18-2016, 09:38 AM   #11
37fordpickup
I painted my rims with a 2 part urethane and since I had paint left over, I also painted my running boards.
37fordpickup is offline   Reply With Quote
Old 09-18-2016, 10:12 AM   #12
DD931
DD931's Avatar
I was planning to remove mine and have them powder coated. Any comments?
DD931 is offline   Reply With Quote
Old 09-18-2016, 11:46 AM   #13
Marvin/TN
Send a message via AIM to Marvin/TN
Powder coating was going to be my suggestion.
Marvin/TN is offline   Reply With Quote
Old 09-18-2016, 12:42 PM   #14
Vics Stuff
Vics Stuff's Avatar
I sprayed my 41 ford truck running boards with 2 coats of rocker shutz. Rocker panel under paint spray covering. lightly sanding between coats to smooth out the coating
to give it that light vinyl texture look . Then top coated it with Acrylic Enamel color with hardner, I cleared it with Poly Urethane ( Imron ) It has been 28 years ago and this has held up real well even with a lot of daily foot traffic.
Would do it again on my next truck in a heart beat. I would actually say it looks the day I sprayed it.
Vic
Vics Stuff is offline   Reply With Quote
Old 09-19-2016, 04:08 PM   #15
DD931
DD931's Avatar
Been doing some research. POR-15 seems to be a good choice, but may be somewhat UV susceptible. So, POR now offers POR-15 TOP COAT, which is specifically UV resistant. Apparently the thing to do is use POR-15 regular stuff for a couple of coats and the put a coat of TOP COAT over that. I think that's the path I'm going to follow. It should be a lot cheaper than powder coating!
Old 09-19-2016, 06:57 PM   #16
Barry-ct
Barry-ct's Avatar
All your suspension parts from the new car makers are powder coated and once it cracks or gets a tiny chip in it, it will trap water under it and things tend to rot very quickly. By the time you find this has happened, it's pretty nasty under the coat. If you're never going to drive your truck in the rain, it might work. I don't think I will use it. There is no metal primer under it on production parts. I have had several John Deere riding tractors where the coating could be peeled off in sheets. Must be a lot cheaper to powder coat for them, than use paint!
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 09-19-2016, 08:01 PM   #17
FortyNiner
FortyNiner's Avatar
Did somebody ask for a picture? POR15 still looks good despite three years of unkind use.
Old 09-19-2016, 08:19 PM   #18
TJ
TJ's Avatar
Take them to any shop that installs spray on bed liner. A friend has done this on his '40 and '35 pickup. and it has held up well. I think he had two running boards done for less than $75.
Old 09-20-2016, 08:00 PM   #19
oldrelics
Thanks guys, I was looking into the bed liner stuff but they want $350 to do it
Old 09-20-2016, 09:48 PM   #20
cmbrucew
cmbrucew's Avatar
https://www.napaonline.com/napa/en/p/DC_TR250/
Napa has bed liner in rattle cans.
May this myself to save removing the boards.
There is also a masking tape with a wire to make straight lines.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
