Old 09-09-2016, 10:15 AM   #1
flatheadgary
Default model a spindle nuts
my brother bought a '23 t race car altered and it had spindle mount front wheels. he wanted to put those 10 spoke "gasser" wheels on, but he didn't have a hub to mount it to. i have a hub and after all is said and done they look great on his car. now here is the problem. his spindle is the rectangle model A without a cotter pin hole. i have looked at parts stores and they look like they have 2 different castle type nuts. is one or the other for this situation? also the reason i am posting on the Ford Barn site is very few people would use model A spindles there i would think.
flatheadgary is offline   Reply With Quote
Old 09-09-2016, 11:04 AM   #2
Jim Brierley
Default Re: model a spindle nuts
I have never seen a spindle without a cotter-pin hole. Having said that doesn't mean they don't exist. You could drill a hole in the spindle with a little care. FYI 1948 nuts are thinner and a larger hex than earlier nuts.
Jim Brierley is offline   Reply With Quote
Old 09-09-2016, 01:19 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Could the hole "possibly" be plugged with cotter remains, from when someone removed the nuts, WITHOUT removing the cotter pins??? I've seen that happen.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-09-2016, 02:07 PM   #4
C26Pinelake
i think there is a good chance that there is a cotter key hole if you examine it closer. Wayne
C26Pinelake is offline   Reply With Quote
Old 09-09-2016, 03:29 PM   #5
SeaSlugs
SeaSlugs's Avatar
Bill W.
yea it can be tricky to spot and Ive had to do this alot to alot of different nuts and bolts on my AA. And im with the other guy - ive never seen any spindle new or old without a cotter pin hole either.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 09-09-2016, 03:59 PM   #6
Safewiz
Safewiz's Avatar
3X, Iv'e done a lot of spindles, I agree, haven't seen any without cotter pin hole. But as stated above, anything is possible. If that is the case, a steady hand and a sharp drill bit could cure that.
Coral Springs Florida
Safewiz is offline   Reply With Quote
Old 09-09-2016, 10:52 PM   #7
flatheadgary
well thanks for the replies guys. my brother will be coming over in a week. we will have to remove a wheel and look closer.
Old 09-10-2016, 09:00 AM   #8
Indiana A. Lover
Send a message via Yahoo to Indiana A. Lover
DO NOT DRIVE CAR WITH OUT COTTER PINS! yes i am yelling at you, I dont want any one hurt. Putting my soap box away.
Indiana A. Lover is offline   Reply With Quote
Old 09-10-2016, 09:00 AM   #9
captndan
captndan's Avatar
More info please about the thinner nut. I retorqued the rear nuts to 90#. Now the hubcaps won't go on because of the cotter pin bent on top of the nut. A thinner nut may solve the problem. I could cut off the end of the axle but the cotter pin hole is only three threads from the end. Any suggestions?
captndan is offline   Reply With Quote
Old 09-10-2016, 09:58 AM   #10
tbirdtbird
bend the cotter to the sides of the nut, not the top
how did it work before you retorqued
please do not cut the axle
'31 180A
tbirdtbird is offline   Reply With Quote
Old 09-10-2016, 10:04 AM   #11
Phil Brown
Phil Brown's Avatar
What car is the front end/spindles from ?
I don't domestic Ford's ever used them but clamp type spindle nuts are not that uncommon
Phil Brown is offline   Reply With Quote
Old 09-10-2016, 10:49 AM   #12
Jim Brierley
1948, and maybe 46-48, had larger front and rear axle nuts. Not sure of the sizes but smaller nuts may be the answer to captdan's problem? If the cotter pin is the problem, cutting the axle will not solve the problem.
Old 09-10-2016, 02:49 PM   #13
captndan
captndan's Avatar
I was hoping someone would shake my tree. Thanks
Old 09-10-2016, 03:33 PM   #14
SSsssteamer
SSsssteamer's Avatar
With our antique steam cars, I make most of my axles out of 4140 tool steel. With custom work on most equipment: If your cotter pin hole is too close to the end of the axle, you can drill another cotter pin hole further in on the axle. If you axle is too long, then cut off the excess axle. If your axle is too short to use the present cotter pin hole and the axle is too short to drill another cotter pin hole, then turn some of the castellated nut back off so the cotter pin hole can line up with the nut. If your axle nut tightens up too soon on the axle to line up with the cotter pin hole, don't back the axle nut off on any tapered axle to the previous hole, you must go on to the next available hole. Can't be done? Either shim under the axle nut, or face some meat off of the axle nut to fit. Remember that you still have to have enough threads left for the nut to safely engage the axle threads. There are hundreds of axle half shaft fixes. A person could write a book on them.
SSsssteamer is offline   Reply With Quote
