#1 |
Today my carb began seeping slowly out of the upper gasket. I drained it and made sure the gas was clean, and re-ran the A for a bit, shut it off and still getting seepage.
Do you guys think I need to take it apart and check the needle for crud and examine the float? Thanks, Jim
"Whether you think you can, or think you can't- you're right." H. Ford |
#2 |
Ethanol gas really does havoc on carbs. I would check the valve and the float. I would also install thicker gaskets.
#3 |
A stuck float can certainly cause the bowl to overflow. With a Tilly there a number of things that can cause the issue. First thing check the 3 screws that hold the top and bottom together and make sure they are tight. I know Ethanol is an easy target but I have never seen it compromise a gasket like that. Heat and warpage are the biggest enemies of pot metal carbs.
Check out this excellent link on Tillitsons and common problems. Tillitson Carbs
Oklahoma City Model A Restorers Group. |
#4 |
If you are taking this TILLY apart for a new gasket you might as well check the two pieces for flatness with a straight edge. TILLYs are prone to warping. If you do see warpage, then search the Barn threads for all of the different methods of correcting this issue from sanding to baking it.
Old time mechanics also used a thin coat of Vaseline on the new carb gasket when assembling. |
#5 |
if the float valve is working properly, the fuel level in the bowl is BELOW the gasket in question. So prolly not the gasket itself or the screws. Start with the float and float valve assembly
'31 180A |
#6 |
Check this out and if it doesn't pan out, follow other suggestions, which will take more time and effort to investigate. Tillies are NOTORIOUS for warping, especially the flange that mates to the intake manifold. But gas won't leak there. Air will just get sucked in and throw off the carb's idling. But, that's another Tilly horror story for another time. Marshall |
#7 |
My thoughts also Marshall....
If the float valve was not holding the car would be flooding, running rich and leaking out the air horn |
