08-21-2016, 01:04 PM | #1 |
help - 1935 colum light switch
hello folks - I'm having a little problem wiring the light switch at the bottom of the column on my '35. As you can see from the pictures below when I opened the bag with my switch loom in it only 1 wire was connected to the Bakelite contact plate. I have no idea where any of the wires should go...
the wires I have hanging in the wind are:- red with a black tracer green with a black tracer yellow with a black tracer there is 2 wires connected which are black with a blue tracer and there is a yellow/red wire and a green wire joined and connected to a terminal but I don't know if they are on the correct terminals on the Bakelite plate. can someone also tell me in which direction the piece on the bottom column should point please. thanks |
08-21-2016, 01:10 PM | #2 |
Re: help - 1935 colum light switch
http://www.vanpeltsales.com/FH_web/F...wiring1935.jpg
Hi Everyone, weemark, check the wiring diagram to see if that clears things up.
08-21-2016, 03:23 PM | #3 |
Very tangled that makes the wiring part easy, figured it out from that diagram. I guess what threw me was the wires are a slightly different - they have reversed the colours and are using the tracer wire as the main colour... Hey ho.
I guess from that I could work out the position of the little spider that goes on the end of the column but if someone was able to confirm the position that would be great |
08-21-2016, 04:52 PM | #4 |
The plate that the wires attach to at the bottom has notches on it that fit into the metal housing. Should be a snap.
08-21-2016, 06:58 PM | #5 |
Hi there, Original Ford switches had all the wires crimped in and soldered to the terminals so no chance of them being pulled off the terminals. Your switch plate must be a reproduction. Make sure those push on terminals are really tight. Regards, Kevin.
08-22-2016, 12:57 AM | #6 |
