Old 08-19-2016, 01:22 AM   #1
Randy in ca
Randy in ca's Avatar
Default Window Channel I.D.
Can anyone give me a positive I.D. on these - I bought them quite a while ago, thinking the ones needed for my '35 3W would be the same as the Tudor - later found out they're apparently not the same and also that my Coupe used the very early style which are also quite a bit different again. Do these appear to be properly labelled as being for 1935-36 Tudor?
Randy in ca is offline   Reply With Quote
Old 08-19-2016, 06:42 AM   #2
Don Rogers
Don Rogers's Avatar
Default Re: Window Channel I.D.
Randy, Those channels look like 35/36 Tudor. I am enclosing images of both tudor and 3 window channels so you can compare dimensions. You might be able to modify the tudor channels to fit your 3 window.
Don
Don Rogers is offline   Reply With Quote
Old 08-20-2016, 06:40 AM   #3
custom_lettering
I had to get repops and they were for a tudor/3w. I had to cut it down to fit my 3w. I'd say if you cut it to the 26 1/16" like in Don Rogers pic you'd be good. Wish I had that pic when I was playing with it.
custom_lettering is offline   Reply With Quote
