Old 08-05-2016, 12:07 PM   #1
JDakota
Default crank shaft pulley
crank pulley is loose and rattles. It looks like not enough room to take off unless I remove the U bolts from the front spring or raise the engine a little. If I loosen the front motor mounts and then I,m not sure about the rear mounts. This on a 1933 Ford 1 1/2 ton truck. Need advice! HELP
JDakota is offline   Reply With Quote
