07-21-2016, 09:11 PM | #1 |
Spent all afternoon installing wishbone ball cover
07-21-2016, 09:25 PM | #2 |
Re: Spent all afternoon installing wishbone ball cover
Does the rubber ball have a hole at the "back" end? If so, hold the open end of the rubber ball against the ball on the wishbone. Then, put your compressed air nozzle on the little hole on the back of the rubber ball. Shoot a little bit of air into it and it will literally leap onto the wishbone like magic. (This has been discussed in the past. Fortunately, I had read it before it was my time to install one.)
07-21-2016, 10:01 PM | #3 |
I installed one on a 1940 wishbone today. Used some liquid soap and a little elbow grease, and it slipped right on. Maybe 41's are different.
07-21-2016, 10:41 PM | #4 |
I slightly oil the edge of the large hole. Then grease my palm and cover the small hole in the other end then push. This causes a pressure build up and it pops right on.
07-21-2016, 11:00 PM | #5 |
One of the K.R. Wilson tools works as claimed (a fifteen second job).
07-22-2016, 02:20 AM | #6 |
I like the sound of using compressed air to help get it on,. |
07-22-2016, 04:30 AM | #7 |
That doesn't look like the correct ball. The correct ball is smooth with no outside (or inside)ribs. Part # B3446 for 1938,39, 40, 41 Ford Ford with 112 in. wheelbase. Let us know if the metal ball cover fits properly. Here's the correct ball.
http://cgfordparts.com/ufolder/fordp...?number=B-3446 |
07-22-2016, 05:20 AM | #8 | |
07-22-2016, 05:37 AM | #9 |
I didn't see that. Sure would be interesting to test each and see which goes on easier.
But, it's a moot now. |
02-01-2024, 12:18 PM | #10 |
I tried several of these methods with no success. In my case I used a 1/2 x 6” bolt in my vise and turned the rubber ball inside out it doesn’t need to be completely inside out then I took the reversed rubber ball and easily pushed it on the wishbone. Jerry
02-02-2024, 01:59 PM | #11 |
I have set the new rubber in boiling water for a few minutes. Goes over the steel ball in a matter of seconds.
02-02-2024, 02:09 PM | #12 |
02-02-2024, 02:19 PM | #13 | |
Glenn
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat's Notes Techno-Source for the 1932 thru 1953 Flathead Ford |
02-02-2024, 02:22 PM | #14 | |
02-02-2024, 02:25 PM | #15 |
Yes!
02-02-2024, 05:59 PM | #16 |
