Old 07-19-2016, 05:43 AM   #1
SofaKing
SofaKing's Avatar
Default Wheel Cylinders Where Art Though?
I put USA kits in my 1939 pu wheel cylinders and three leak, due to corrosion pitting I could not hone-out.
I searched the old threads and they suggest that I should buy new USA wheel cylinders which are available at NAPA and C&G but these threads are years old. NAPA's website has no parts available and C&G only has a right rear.
Does anyone have a current source they have used recently for buying a serviceable set of 4 wheel cylinders?
Has anyone replaced the 1 1/4" cylinder with a 1 3/8" and how did it work? (1 3/8" is available at Rock Auto, whereas 1 1/4" is not)
Is the mis-drilled feed hole still a problem on the chinese stuff?
Thanks.
SofaKing is offline   Reply With Quote
