Old 07-14-2016, 10:30 AM   #1
Jason in TX
Jason in TX's Avatar
Default Will Long snout 36 wide five drums go on 34 style spindles?
Hello! I am wanting to use the 32-34 spindles because of the integrated steering arm, but would like to use 36 wide five drums. I know 36 wide 5's have a longer outter bearing snout that 37-39.
Think I'll run into an issue? I'll be using 39 Lincoln backing plates with the spindle bolt spacing adjusted for the 32-34 spindle, so backing plate is no problem.
Thanks!
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 07-14-2016, 10:36 AM   #2
Chris
Chris's Avatar
Default Re: Will Long snout 36 wide five drums go on 34 style spindles?
They should bolt up fine.
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 07-14-2016, 10:46 AM   #3
Ed Pitts
Ed Pitts's Avatar
Jason, here is a discussion a few days ago. Ed
https://www.fordbarn.com/forum/showthread.php?t=200312
Ed Pitts is offline   Reply With Quote
Old 07-14-2016, 06:44 PM   #4
26 lakes
Jason,
Get in touch with Richard Lacey at Early V8 Garage. Just run everything by him. He helped me with my project. I am running early spindles with the 1936 wide five drums. I am using original 1939 Lincoln backing plates also. I have the original brake drums if I ever want to run wires.
26 lakes is offline   Reply With Quote
