#1 |
I am asking about the elongated water passage located in the lower left corner of the head. As can be seen, the passage in the gasket is a small hole but the block and head is the elongated hole.
I did call BEST and asked why they failed to cut the passage to the original size like many of other gaskets I have used. He said that they had a few people wanting to slow the water flow down so they put the smaller hole in. I told him that everything I have read indicated to me that the purpose of smaller holes at the front of the heads and larger to the rear was to expedite a good flow of coolant to and from the rear of the head. He said I could use a hole punch to enlarge the hole. I said that in all the reading I had done both on the web and in books I couldn't remember hearing of anyone wishing that passage was smaller. Thoughts --- and thanks, Fourdy |
#2 | |
![]() Quote:
#3 |
Seem to recall that some of the early gaskets may have had full sized holes but Ford re-designed them for better cooling properties.
Best gaskets didn't "fail" to do anything, they just made them the way Ford designed them. |
#4 |
34PKUP is correct. Ford changed the design of their later head gaskets to force more water from the front of the heads to the rear for better cooling. I know I read that in the 1949-51 Mercury Overhaul Manuals but I can't quote it right now for this post.
#5 | |
![]() Quote:
" I did call BEST and asked why they failed to cut the passage to the original size like many of other gaskets I have used. He said that they had a few people wanting to slow the water flow down so they put the smaller hole in. I told him that everything I have read indicated to me that the purpose of smaller holes at the front of the heads and larger to the rear was to expedite a good flow of coolant to and from the rear of the head." |
#6 |
Anyone have a comment about opening it up for more flow? Thanks again, Fourdy |
#7 |
I agree that trying to open the gasket up for more flow will only accomplish one thing - a destroyed gasket. Is there such a thing as a hand held water jet cutting machine or a laser that could produce a clean cut? How about the old tried and true X-ACTO knife? The high price of gaskets makes experimentation expensive.
#8 |
I would just buy a Ford mfg gasket which I have in stock.
#9 |
A Dremel tool at high speed with a carbide cutter.
Another way to do it is to sandwich the gasket between two metal pieces clamped together, or even two pieces of wood. I've used this method for drilling/machining parts from shim stock. John
Houston, Tranquility base here. The Eagle has landed. |
#10 |
I've used the best gasket with the small hole on my 51 8ba and have not had a problem.
So my question is, is this supposed to be an improvement to balance water flow. |
#11 |
i just uz then the way they come out of the box. Seem to work fine. My 280 runs 180 here in the hot Vermont summer with 180 stats. So I don't think it's am issue.
