Old 07-02-2016, 06:26 PM   #1
kwisor
kwisor's Avatar
Default clutch release shaft arm broke
hello all put a new top on the car today went for a ride and the clutch started getting out of adj I made it home but could not disengage the clutch came on the barn looked up clutch and read a thread that the arm is bad for braking I looked at did not see anything so I adj the pressure plate arms because I had about a 2" play when i pressed the clutch that is when I found the crack I guess the pressure was to much now I will have to adj the arms again when I get the new arm luckily smith and jones is 2 miles from my house so will get a new one tue thanks to the barn I don't have to pull the transmission
kevin
1930 tudor
kwisor is offline   Reply With Quote
