Old 06-30-2016, 09:00 PM   #1
flathead4dr
flathead4dr's Avatar
Default 59AB engine
How can you identify a 59AB bare block from any other 59 series block that have a "59" cast onto the bell housing ??
Old Fords make funny noises.
flathead4dr is offline   Reply With Quote
Old 06-30-2016, 09:29 PM   #2
JSeery
JSeery's Avatar
Default Re: 59AB engine
What differences you are referring to? Bore size? That can be easily checked.
Old 06-30-2016, 10:57 PM   #3
flathead4dr
I was thinking there was a couple of years earlier that were "59" engines but did not have the "AB" cast on the heads for some reason??
Old 07-01-2016, 01:45 AM   #4
scooder
There were 59 blocks that had 3 1/16" bore aswell as 59 blocks with 3 3/16" bore. 59AB on the head only means it's got 59AB heads, nothing more nothing less.
Pretty sure all the 3 3/16" 59 blocks are the same, all the ones I've seen are. The 59AB heads are a little higher compression than the earlier heads, I have measured these at 76 cc +- the earlier heads including the 81A heads measured 80 cc +-. Interestingly the 8BA heads I've measured have 80 cc +-. If you lay them combustion chamber up, you can see the 59AB heads have a different chamber shape than the earlier and 8BA.
Martin.
scooder is offline   Reply With Quote
Old 07-01-2016, 08:26 AM   #5
flathead4dr
Thanks Martin. This is the information I was looking for. Bill
