06-27-2016, 05:49 PM | #1 |
1934 ford pickup-powet steering?
Looking to put a cross steer power steering box on my 34 stock front end with proper steering arm for conversion. Have seen nothing but manual units, Vega,etc. Has anyone tried this? Steering this is a handful at slow speed and maybe even my wife can enjoy it!!!!
06-27-2016, 05:53 PM | #2 |
Re: 1934 ford pickup-powet steering?
I'd go for an electric unit, Inexpensive and they work great. Not sure how to put one in a 34 tho??
06-27-2016, 06:36 PM | #3 |
What tires/wheels are you running??
Paul in CT |
06-27-2016, 09:21 PM | #4 |
17" wires, Kelsey-Hayes , I believe
06-27-2016, 09:43 PM | #5 |
Mike,
Find someone that has installed the later pick up truck steering and try it. It should give you what you need, look better and probably cost less. Have you compared your steering with other stock steering cars to see if the problem is just your box? Charlie Stephens |
06-27-2016, 09:51 PM | #6 |
06-27-2016, 10:43 PM | #7 |
Is it safe to assume that your existing steering box is properly adjusted and lubricated? Remember that the car should be moving slightly when you turn the wheel.
Charlie Stephens |
06-27-2016, 11:39 PM | #8 |
Yes can be done did my 34 Roadster best PM for more information it's worth doing parking is a breeze and you will keep things pretty well original
06-28-2016, 10:03 AM | #9 |
750.00
06-28-2016, 10:20 AM | #10 |
You should leave it the way it is. That way your wife will build up the biceps and then she will be able to carry a heavier burden and do more chores like in the old days....☺☺
Matt 24:36-41 |
