Old 06-27-2016, 02:57 PM   #1
Woodie1
Woodie1's Avatar
Default Cap Jet
Has anyone had trouble keeping the carburetor cap jet clean? I had to clean one out on our 29 last fall & I just had to do it again today. I have never had that problem before. I have the screen in the gas shut off that sticks up into the gas tank. I have the cast iron sediment bulb & I'm pretty sure I checked that last fall. I removed the fuel inlet strainer & that looked clean. I did notice shimmering dirt in the carb bowl when I removed the lower half.
Woodie1 is offline   Reply With Quote
Old 06-27-2016, 06:43 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Cap Jet
Have you ever looked inside the cast iron sediment bowl?
I've sandblast a lot of rust out of some.
Old 06-27-2016, 08:26 PM   #3
Woodie1
Woodie1's Avatar
Default Re: Cap Jet
I did last fall but was more interested in the filter in it than the condition of the casting inside. Guess I'll have to look at that. I know I blasted it when I restored the car about 32 years ago. That's been awhile.
