#1 |
Hi guys,
I am attaching a couple of pics of some 8BA bell housings I have. Glad I cut my toenails LOL. The mission here is to mate my 8BA to 39 type of top loader in my 31 Roadster. The case is a 78. I have two types. A cast iron one and a steel one with the starter plate. I believe the cast iron one is the one I need to use but am not sure of the starter plate. The motor I am using has the truck oil pan with the bottom access door. Any help is greatly appreciated. Thank you. |
#2 |
Have you looked at the often posted paper on bell housings?
#3 |
Do as the above gentleman suggested via the SEARCH.
The steel bellhousing with the starter plate you have looks like the 49-51 Merc. That is the one that will work for you. It will take the 10 inch clutch. Tons of info. has been posted on your topic. A SEARCH will make you a happy man. I believe 39 and 40 transmissions have the same bolt pattern for that Merc bellhousing. I used one in my 40 but it will also work with a 39 transmission. The only advantage of the cast iron truck bell housing is that it will take an 11 in. clutch. 11 in. is not needed as a 10 in. will work fine. Have had a 10 in. in my 40 with an 8BA since 1970. The 49-51 Merc. oil pan is also a better choice in my opinion. Start here. https://www.fordbarn.com/forum/showth...d+transmission Last edited by 19Fordy; 06-17-2016 at 05:47 PM. |
#4 |
yup, lots of info out there. van pelts web site has a great ID section for bell housings. either of what you have will take 32-48 trannys, unless your steel one is for the 6 cylinder. check to see that it mates up to the block
#5 |
