Old 06-17-2016, 03:19 PM   #1
russcc
Default Head gasket squish
I clayed up the pistons & valves on a 59AB, and cranked it over by hand with the heads/gaskets on. The clearance between the head, pistons & valves is good. What I would like to know is how much does a typical metal/composite head gasket that measures .080 thick new, compress to when torqued down to 50#s. Using almn heads. Thank you Fordbarners.
russcc is offline   Reply With Quote
