Old 06-10-2016, 04:20 PM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 1939 Ford Window winder Mechanism.
The window winder mechanism has two rollers on the operating arms for fitting into window channel for operating the window.
On drivers side these rollers complete with tension spring and channel roller guide are worn and need replacement.
Can they be purchased without the complete window mechanism?
Is there a part no for these?Appreciate assistance as cant seem to locate in the Green Bible.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 06-10-2016, 04:54 PM   #2
Anton Voycheck
Anton Voycheck's Avatar
Default Re: 1939 Ford Window winder Mechanism.
Phil NZ
You won't find it in there. Green Bible is a Chassis Catalog.
You need the Body Parts Catalog for your year of Ford.
Anton Voycheck is offline   Reply With Quote
Old 06-10-2016, 05:49 PM   #3
swoopNZ
MEMBER EMERITUS
No parts breakdown in any of the manuals I have.
Find yourself a 37-39 fordor rear door window regulator and use the parts from it.
Usually less wear than the front door ones.
Regards,
Chris.NZ.
PS: You have to watch out saying Drivers' side on this forum.
That's the LH side to them.
swoopNZ is offline   Reply With Quote
