#1 |
When you hook up a 1 wire, Positive ground alternator the out wire on the alternator connects to negative battery terminal. Is the correct, Thanks, Steve
#2 |
Here are the instructions from the positive ground alternator that I have.
http://www.powermastermotorsports.co...6_PowerGen.pdf
Ryan Scardina Livingston, Louisiana 1930 LSU Model A |
#3 |
Thanks
#4 |
That's correct but the ammeter is in the middle of the wire, along with a few terminal connections.
#5 |
