Old 06-01-2016, 03:12 PM   #1
1wonton
Default Generator
Will the generator be damaged if I disconnect it from the battery while the engine is running?
1wonton is offline   Reply With Quote
Old 06-01-2016, 03:18 PM   #2
Bob C
Default Re: Generator
Most likely if you are just running a cutout.
Bob
Old 06-01-2016, 03:26 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Yes it will because the voltage can jump to 40 volts and overheat the windings. If you ground out the generator output stud, then you can safely run it without being connected to the battery.
