Old 11-05-2010, 03:28 PM   #1
Russ/40
Russ/40's Avatar
Default Gas leak at column support
Before I did the body and finish work on my '29 gas tank, I put a few gallons of solvent in it to check for leaks. I found none. Now that it is ready for final paint, I see a slight weep at a corner of the column support bracket. Is there a successful way to stop this weep without destroying all my body work?
Russ/40 is offline   Reply With Quote
