05-23-2016, 05:36 PM | #1 |
50 F-1 gas tank question?
I had my gas tank in my 50 F-1 cut open and coated inside with RedKoat tank sealer. It was done 4-5 years ago and the stuff is supposed to be ethanol resistant. Ever since then, the gas is red, like cherry soda is. They did it again and same deal. So, I am going to get a new steel tank. No more dealing with used or the sloshing compound.
My question is to those who have replaced your tank in your truck with a brand new one. Will the original fuel tank unit bolt into a new tank without having to adapt or redrill the tank? I want to install and get back to my project after 2-1/2 years. My truck is getting lonely sitting in the garage.
Barry 50 F-1 |
05-23-2016, 06:34 PM | #2 |
Re: 50 F-1 gas tank question?
I bought a new tank in 2013 for my 50 f3. i think it came from lmc.
fit with no issues. was even red like my interior! after reading the problems people have trying to save the old ones i wonder for $200 or so, why? cliff |
05-23-2016, 06:36 PM | #3 |
I thought I read that the fuel sender does not fit the new tanks but I could be wrong. I know Ken Krans got a new tank last year maybe he will chime in.
Respecting and Resurrecting Ford Model A's. |
05-23-2016, 07:41 PM | #4 |
I bought a new tank for my '49 F4 from Bob Drake. I believe the old sending unit will fit. I can double check tomorrow. I saved the old unit just in case the new one gives me problems.
Mark |
05-23-2016, 08:11 PM | #5 |
Some of the tanks come with two sets of holes so you can use an original or aftermarket sender.
05-24-2016, 03:54 AM | #6 |
05-24-2016, 06:01 AM | #7 |
Yes, my truck needs to be done, Ken. I'm tired of seeing it just sitting there. I will check Speedway and see. I need to order it while I have some extra $$ from repairing lawn mowers. Lucrative sideline, but gets in the way of working on the truck!
Barry 50 F-1 |
05-24-2016, 08:21 AM | #8 |
I did some checking and with the free shipping on the first order, It is now $249.00 at Speedway. LMC is $199 plus a $20 oversize charge with $27.50 shipping. C&G is $260 plus shipping. C&G's tank says you can't use the original unit. I hate to have to jury rig things to make it work.
Barry 50 F-1 |
05-24-2016, 09:59 AM | #9 |
Someone (Classic Haulers?) sells a 5-hole to 6-hole adapter to use the original sender with a new 6-hole tank, or vice versa.
'52 F-1, EAB flathead |
05-24-2016, 12:55 PM | #10 |
Well, I ordered the speedway tank. we will see.....
Barry 50 F-1 |
05-24-2016, 05:12 PM | #11 |
The original sending unit will fit the Bob Drake tank.
Mark |
05-24-2016, 05:51 PM | #12 |
Barry, I did a lot of checking on the net and cannot find a tank any cheaper then what you have found. I still do not understand the red color as that coating should have dried long ago. Good luck friend.
The sign of a good craftsman is how well they cover up their mistakes. |
05-24-2016, 06:29 PM | #13 |
Can't explain it either. Now I have to drain and dispose of it properly. I am going to remove the carb and open it up to see what's in there. I have another one rebuilt to go on it. I have to get one of those flex lines with the check valve in it to complete the installation.
Barry 50 F-1 |
05-25-2016, 11:10 AM | #14 |
You can dispose of it properly buy putting it in the gas tanks of your mowers.
05-25-2016, 07:42 PM | #15 |
I'll try that.....
Barry 50 F-1 |
