Old 05-22-2016, 06:27 PM   #1
waltere
Default 36 hub repair
I need some advice from the experts. The right rear hub on my roadster has some movement that concerns me. Everything is new and in great shape as well as the spindle nut torqued to 220lbs and well as torqued after 50 miles. I am assuming the taper on the hub and the axle are wore differently. Is there a good repair or shims to repair this problem?
Thanks in advance! (1936 ford rear)
Walter
waltere is offline   Reply With Quote
