Old 05-21-2016, 04:56 PM   #1
kwisor
kwisor's Avatar
Default need to adj spark rod
hello
I did a search didn't find anything I need to turn my steering column to adj my spark laver I took the brkt loose at the bottom and took the brkt loose under the tank but can not turn the column is there anything more to take loose or how hard is it to turn
thank you kevin
1930 tudor
kwisor is offline   Reply With Quote
