05-20-2016, 06:49 PM | #1 |
Distrubitor vacuume line
Any one know where to find a vac line that goes from Dist to plate under carb? 1938 ford!!
05-21-2016, 06:40 AM | #2 |
Re: Distrubitor vacuume line
Enjoy yer day. Tom Hate can't fix what it started. |
05-21-2016, 06:41 AM | #3 |
The 38 Ford set up is a metal vacuum line from the distributor to the intake manifold left side, bottom, front. There is a second vacuum port on the intake manifold left, bottom, rear for the vacuum wiper motor. There is not a plate under the Carb. so you will have to either change your set up or improvise. Can you post a photo of what you have? Maybe the intake manifold was changed???
05-21-2016, 11:19 AM | #4 |
Try Roy Nacewicz, he had one for my 34 5 window coupe.
(734) 654-9450 |
05-21-2016, 11:31 AM | #5 |
Here's a picture of the underside of the intake vacuum port. I noticed on mine that the newer gasket material "mushed" into the groove. Ended up putting a small V with a razor blade in the gasket. Not all the way through the gasket mind you.
05-21-2016, 12:16 PM | #6 |
05-21-2016, 12:34 PM | #7 |
Hey Joe, It may or may not be an issue. Might just want to blow through the line to see if its clear. It may well be. I guess you could also clean out that channel with a burr slightly. Especially if you've had the intake resurfaced.
