#1 |
Does anyone know where I can find a caged roller bearing the following size?
Inside diameter is 1 inch Outside diameter is 1-1/2 inch Length is 2 inches If you have to know.... LOL it is for the cast iron wheel for a cart for a hit and miss engine Any help will be appreciated. |
#2 |
I can't tell where you're located.
In SF,Ca. there is a place called Bearing Agencies. I think that it's on 7th ST. It's a bearing specialty parts house. There's a pretty good chance that there's one in a larger city near you. I have a bearing book, it shows a lot of bearings by size and type. Just don't have time right now to go thru all this... PM me if you're interested Karl |
#3 |
Walter, as Karl mentions, check for a independent bearing distributor in your area, there are a few around. Are you looking for a needle roller bearing type or the old New Departure / Hyatt type?
Henry Ford designed the flathead without the aid of a computer. |
#4 |
If you´re not gonna use it a lot you might get away with making a bushing perhaps ?
#5 |
Bearing Distributor Inc. BDI or Applied industrial Technology. Just a couple of bearing supply houses.
#6 |
#7 |
If it's just a cart bearing, why not two smaller width bearings with a spacer in between?
#8 |
google "roller bearing size chart" to calculate a part number. For example,
http://www.skf.com/binary/79-66347/457013.pdf Jack E/NJ |
#9 |
A quarter of an inch on each side is not a lot of room for bearings. Some of these type bearings are not caged but they are plain needle bearings. Where a caged bearing would be workable is if the center shaft doubles as the inner race with a thin shell outer race or the bearing support forms the outer race. Harley Davidson crank pin bearings are made like this but they aren't that long. This application might be hard to source in this day and age. A person could gang several together with hardened separator rings in between.
#10 |
Torrington perhaps?
#11 |
Click on some of these images that look close to what you want and you might find a supplier. Some of them look like the roller bearings in the Ford rear end and old Atlas lathes, which if I recall are the same bearing.
https://www.google.com/search?q=%22n...w=1366&bih=651 Jack E/NJ |
#12 |
Thanks for the input. Seems as if I am going to try and just make a bushing for the wheel.
