Old 05-16-2016, 06:42 AM   #1
Charlville
Charlville's Avatar
Default Flasher Advice Please
Hi All
I have a turn signal issue that I wonder if anyone else has experienced and can help with please?
Parts installed as follows:
12volt negative earth system
Universal Flasher Switch
(https://duksville.myshopify.com/prod...ignal-switches)
The in bumper lamps from Bert's (12v bulbs fitted)
(http://parts.modelastore.com/show_Product.asp?ID=4350)
An electronic flasher unit with pins 49. 49A, 31, C
(http://www.vehicle-wiring-products.e...-flasher-relay)
The issue I have is that the side to side and hazard functions work but the tell tales in the switch don’t illuminate and the flashers flash too fast.
I’ve looked at earths and this looks OK, just wondered if you’ve come across this before please?
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 05-16-2016, 07:16 AM   #2
Dollar Bill
Dollar Bill's Avatar
Default Re: Flasher Advice Please
Look down below for a previous thread regarding the T/S indicator lights not working - Usual culpret is poor ground.
Rapid flashing may be resolved with a different flasher.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 05-16-2016, 08:40 AM   #3
tbirdtbird
it can be difficult to get a proper ground for the tiny tell tales in the flasher unit to work.
Next, I have not had good luck with any electronic flashers (china) and always end up with the 6 ohm resistors (one on each side of the car) to create a load sufficient for an old school thermal flasher to operate.
We run into this all the time when we install the LED tail lights in the teacups.
If there is someone out there who has found an electronic unit that works I am sure we will hear about it
'31 180A
tbirdtbird is offline   Reply With Quote
Old 05-16-2016, 10:44 AM   #4
Fullraceflathead
Fullraceflathead's Avatar
Look away unless she's very good looking!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 05-16-2016, 12:17 PM   #5
Charlville
Charlville's Avatar
Ha ha, nice one
Kevin Flood
West Berkshire UK
Old 05-16-2016, 02:45 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Check to see if there are even a bulb in the unit.
The switch is designed for the 3 wire flasher. How do you have the 4 terminal flasher wired in the circuit?
Like DollarBill says the indicator need a good ground to work.
