Old 05-13-2016, 11:39 AM   #1
1Tudoor
1Tudoor's Avatar
Default annoying rattle
For some reason I started getting a rather loud rattle from what sounded like the top of the drivers door which turned out to be the rod connected to the open handle on my 31 Tudoor .
There are numerous ways to go at this , maybe some more desirable than the small rectangular pieces of an old credit card I curled between the rod & door & held in place w/ a drop of super glue .
I hope the judges don't notice !
1Tudoor is offline   Reply With Quote
Old 05-13-2016, 11:44 AM   #2
Utopia Texas
Utopia Texas's Avatar
Default Re: annoying rattle
If you use a vintage credit card the judges will not take off any points.....
Utopia Texas is offline   Reply With Quote
Old 05-13-2016, 12:14 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
A couple felt pads glued to the door skin should keep it quiet.
Old 05-13-2016, 12:57 PM   #4
Gyrodoc
Gyrodoc's Avatar
I think I have that problem also. I assume you have to remove the door panel to fix this?
Richard
Gyrodoc is offline   Reply With Quote
Old 05-13-2016, 02:03 PM   #5
1Tudoor
1Tudoor's Avatar
Richard
On mine, I removed the garnish molding , door handle , & one capped screw halfway down the rear edge of the panel which allowed enough access .
If you have the aluminum upper door seal held down by the garnish , don't let it fall down in the door or then panel removal is req'd .
I fastened my 4 door seals w/ dabs of Goop prior to the garnish to prevent that --great stuff for a lot of things .
Old 05-13-2016, 05:40 PM   #6
Gyrodoc
Gyrodoc's Avatar
!Tudor,That help a lot Thanks
Richard
