#1 |
Looking for some advice on adding turn signals. My car has a single tail light/brake light. Everything is still wired through the switch on the end of the steering column. I would like to get opinions on the easiest way to add some directionals. I think I have seen some people add cowl lights and make them turn signals? I would like to keep it as simple as possible. Does someone make a nice kit perhaps? The car is actually my father's and he loves driving it but he would feel more comfortable with turn signals. Any thoughts would be appreciated. I have gotten a lot of help from you guys and really enjoy this site. Also hoping to get my 56 out on the road this summer...
#2 |
Came across this a while back. I wil try to attach it
#3 |
Do a search on "turn signals" or "directional signals" - you'll find a ton of material to read. The solution you choose will depend on whether your car is still 6 volt pos ground, whether you intend to install a second tail light, etc. There's at least one system available that doesn't require running any wiring.
Dave |
#4 |
I have an earlier version of Logo Lights (previous owner installed) and like them. The controller is magnet mounted under the fuel tank and well hidden. Russ
#5 |
Young drivers have no clue to hand signals.
Do they even teach this anymore?
#6 | |
While riding in my Town Sedan my Grandson and his friends (all just starting to drive) were laughing at how many people didn't understand my hand signals. They even pointed out that some friendly drivers actually waved back... ![]() ![]() I think the ONLY driver on the road that day that actually knew hand signals was a BIKER we were following. HE was using hand signals also. ![]() Last edited by Y-Blockhead; 05-13-2016 at 04:16 PM. |
#7 | |
![]() Quote:
And that is the reason I put signals on my car, got tired of people turning in front of me, almost rear ending me, and waving. I don't mind people waving, but not when I was signaling.
#8 |
Waving ? You guys have people wave ?
The soccer moms give me the single finger salute ! I finally broke down and installed signals. After being rear ended I decided to change to LEDs. |
#9 | |
![]() Quote:
And yes I have broken down and installed turn signals and a third brake light. And a "Slow Vehicle" Triangle. None of it seems to help... ![]() ![]() ![]() And wouldn't it be wonderful if people had to come to a complete stop at a stop sign in order to put the trans in first gear? as we do with a non-syncro trans? Don't get me started... ![]() ![]() |
#10 |
GAR64 I just recently went through this same process. I, too, experienced issues with people not knowing what hand signals are, even having some waving to me as if waving back.
So, I decided to install turn signals on my 1930 Model A Deluxe Coupe, with the original 6 volt system. The coupe has the single rear light mounted on the left rear fender. I did not want to drill holes in the good right rear fender, so opted to install a set of lights on the front and rear to be used. I also did not want a set of gaudy lights so as not to detract from the Original Model A appearance. After much searching, I was able to locate a pair of amber lights for the front, to be used as turn signals only. For the rear, I also located a like pair of red lights, to be used as turn, tail and stop lights. The lights are manufactured by United Pacific Industries(See Attached files). I am including pictures of the Model A showing the front and rear lights installed. Hope this helps, GAR64, and good luck. |
